fuel pump advice
Hi all,
My mechanical fuel pump is dead
Thinking of replacing it with an electric fuel pump.
The car is running twin 45's and sprint cams.
Any advice on what pump to use would be greatly appreciated.
Many thanks,
Many thanks,
Cars:
Restoring
69 Elan +2
Running
73 Europa Special
Restoring
69 Elan +2
Running
73 Europa Special
- Cymru
I went facet electric pump (the cylinder type)
And malpassi fuel regulator to get the pressure right
Plus hoses...and you will need little rubber mounts for the pump to reduce vibration
And you will need a way to turn it on and off...I used a switch in the cabin...
There is some clever discussion on the forum about an auto-cutoff of the fuel pump too...
LaikaTheDog - Third Gear
In addition to an impact switch, think about a fuel cutoff solenoid between the electric fuel pump and the bottom outlet of the fuel tank. It also provides an easy way to prevent fuel flow when working on the carbs and having a full fuel tank.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
I fitted a Facet (cube shape) pump in my Elan in 1972 and its still working fine.
Originally I put it in front of the radiator and it was there for about 10 years exposed to the elements so when I fitted a new chassis a dismantled the Facet pump and had its parts cadmium plated (it was easy in the 1980s) and it is now mounted in the boot with an in-line filter.
The mount consists of a wodge of foam rubber which is wrapped round the pump and is stuffed down the gap at the side of the fuel tank.
I found a spare wire in the rear loom so its now controlled by the ignition switch.
Ian
Ian
Elanman99 - Fourth Gear
Although I have not tried it yet based on the information in this forum I think I'm going to go with a "Huco" fuel pump for my project. It's delivery pressure is specifically set for Weber/Dellorto carbs so no separate regulator is required. See link below
https://classiccarbs.co.uk/product/huco ... in-germany
Note also here in Australia at least it is illegal to place a fuel pump, lines or filter in the passenger compartment or boot unless the car was equipped with such a set up originally. Might be something else to consider.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
I fitted a Huco - https://www.dellorto.co.uk/shop/car-acc ... ump-133010
It is specifically designed for carbs - low pressure and high volume.
As stated above, there are other benefits as well. Switch the pump off and you can spin the engine without pumping fuel. Use the pump to drain the fuel tank. Prime the carbs before starting. Etc.
Incidentally, having fitted the pump virtually all the fuel stink in the garage has gone.
Down side - it does make getting to the distributor even more awkward!
- vincereynard
vincereynard wrote:You've baffled me Sandy!
Frequently!
Put the pump in the boot, I reckon, though the pipes have to bend tightly. Plenty in the archive including
lotus-carbs-f40/fitting-electric-fuel-pump-t26800-45.html
with bits from Alex Black and myself on page 4.
Meg
I went with the Facet cube type as well. Pressure worked out OK for my SU?s; haven?t tried it with the new Weber 45?s yet but thinking it should be OK so no plans to change it. I think they are ~2 psi output IIRC? I bought a spare which I keep in in the boot in a ziploc bag with a spare filter element. Think Moss or Victoria British sell them.
Mounted it outside the boot, right side of the car, on the boot front bulkhead (where I could get easy access for mounting screws & nuts both sides). Used thick rubber washers to isolate & weather seal. Was rewiring the car so ran a power wire from my main fuse box; can?t remember if I used a separate relay for the pump power but not a bad idea. Ground wire to the main rear ground, (which I have relocated from the boot floor / frame hex screws to the large body bolt tapped in to the right side suspension tower).
Over five years & miles of smiles with no issues.
HTH
Stu
HTH
Stu
Stu
1969 Plus 2 Federal LHD
Not all Facet cube pumps are equal. There are at least three versions. You need to check the specification before purchase. As has been said 2 to 2.5 psi for carbs.
- elanman999
