Fuel filter partial vacuum?
PostPost by: vincereynard » Wed Nov 01, 2017 2:17 pm
I have just fitted a Huco "sucker" pump and it is not delivering anything like the flow it is specified
to acheive. I'm going to bench test it pumping between containers with new 8mm hose on both sides.
A possible / potential problem I have noticed. I had 6mm to the filter and 8mm filter to pump.
Naturally the 6mm cannot keep up with the 8mm and the filter empties!
Therefore it would have a partial vacuum inside the filter?
Options ??.
1/ Drop filter so it is below pump (The +2's high mounted tank -
little help from gravity except with a full tank.)
2/ Run 6mm also from filter to pump. (However the nylon is 6mm external,
the rubber 6mm internal, so the pipe from the tank would still be a
partial restriction.)
3/ Mount filter after the pump so the fuel is being pushed through it.
An suggestions?
PostPost by: 2cams70 » Wed Nov 01, 2017 3:02 pm
Check the tank or fuel cap venting. Take the fuel tank cap off on a temporary basis, try again and see if things improve.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
PostPost by: alan.barker » Wed Nov 01, 2017 3:55 pm
If you still have the original very big breathers on a +2 i would not think it is lack of tank venting.
I always keep the filter between tank outlet and pump. This keeps the pump clean.
Imho you need the same dia through all the length of the fuel line upto inlet on carbs.
Have you tried to see if car runs without measuring flow rates :wink:
I'm sure the Huco flow rate is still more than the old ac delco mechanical pump.
PostPost by: Craven » Wed Nov 01, 2017 4:19 pm
In a practical situation the pump will not be delivering fuel at its rated output, therefore your test setup is not really relevant.
As the total carb input is 2x 1.75mm then test with an output restriction of say 4mm.
Edit Sorry Typo
PostPost by: vincereynard » Wed Nov 01, 2017 7:48 pm
Craven wrote:In a practical situation the pump will not be delivering fuel at its rated output, therefore your test setup is not really relevant.
The test was mainly to establish if there was a fault with the pump.
With an 8mm inlet and 6mm outlet it pumped 3.3 litres in 2 minutes. Reversing the pipes made very little difference. Blowing through the filters offered no real resistance.
Yet connecting the pump to the filter outlet only pumped a meagre 250 > 300 ml a minute.
Logically the feed pipe must be offering serious restriction of some sort??
Is a 6mm (external) nylon pipe the usual feed from tank to pump? The internal diameter is about 4mm.
PostPost by: pharriso » Wed Nov 01, 2017 7:52 pm
Original nylon pipe is 1/4" (6.35mm) OD
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: alan.barker » Thu Nov 02, 2017 4:38 am
I would think that's more than twice the amount of fuel the car needs.
Sorry but have you tried driving the car yet.
Please take it for a test drive :wink:
PostPost by: vincereynard » Thu Nov 02, 2017 3:02 pm
alan.barker wrote:I would think that's more than twice the amount of fuel the car needs.
The last 3 times I did that it did not end well!
80mph at 20 mpg (?) = 4 gallons per hour.
30ml X 60 = 18litres = 4 gallons
Sounds marginal to me or are my maths rubbish?
PostPost by: nmauduit » Thu Nov 02, 2017 4:24 pm
vincereynard wrote:With an 8mm inlet and 6mm outlet it pumped 3.3 litres in 2 minutes. Reversing the pipes made very little difference. Blowing through the filters offered no real resistance.
3.3l/2min gives about 30gallon/hour, which should me more than enough for a 200+ HP engine : since issue only arises with the filter before the pump, it could be that the filter is already clogged ... or that it prevents the pump suction for normal operation. I doubt that some air/vacuum build up within the filter would have any effect, but you should easily see that with longer hoses allowing the take the filter further down for test purposes.
then checking filtering particle diameter : you may want a coarser pre-pump filter and a finer post pump filter if indeed your pump can push but has a hard time to pull.
S4SE 36/8198
PostPost by: alan.barker » Thu Nov 02, 2017 4:58 pm
I thought 70 mph in UK was max on motorways :wink:
Maybe a bigger/larger filter would restrict less.
PostPost by: vincereynard » Thu Nov 02, 2017 5:59 pm
Tank fuel pipe connection blocked by insulation. That cannot have helped!
s1840001.jpg and
s1840002.jpg and
s1840003.jpg and
Perhaps it was floating in the fuel until I drained the tank? Then got sucked into the union and
lurked there just waiting. How it got into a new sparkly tank is a mystery.
I'll flush the tank out with a couple of gallons just in case.
PostPost by: alan.barker » Thu Nov 02, 2017 6:35 pm
Looks like machining swarf to me :evil:
Good job you put the filter before the nice new Huco 8)
I must admit the outlet at the very bottom of the tank on a +2 is not a very clever design + it's a pain in the neck to access :wink: .
Well done Vince you'll get there in the end. Can you see the light at the end of the tunnel :?:
PostPost by: vincereynard » Fri Nov 03, 2017 7:42 pm
alan.barker wrote:I must admit the outlet at the very bottom of the tank on a +2 is not a very clever design + it's a pain in the neck to access :wink: .
Not very clever design is one way of putting it! Design by whatever is cheapest I imagine.
P.S. With the rubbish removed the Huco now pumps a steady 1.1 litres a minute from the carb. joint pipe.
So that OK .
