+2 lockable filler cap mod help pls
. I'm very happy with the grooved filler neck i bought from sjspares to go with the lockable filler cap i acquired ... but there is a problem ....corresponding with steve at sjspares he is unable to help me with a longer rubber elbow which is required as the new filler neck is 3 " shorter than the old standard one .
Can anyone suggest where i might find a version of the +2 rubber elbow but with the extra length?
RichC
RichC
RichC - Fourth Gear
I had a top hose made by these boys when I fitted a Burton stat housing/filler.
I am sure they will be able to help
http://www.derbyperformancehose.co.uk/v ... -hose.html
silicone may be better for fuel odour too?
Jon
Jon
- jono
"corresponding with steve at sjspares he is unable to help me with a longer rubber elbow which is required as the new filler neck is 3 " shorter than the old standard one"
this sounds a little odd?
I'm not so sure about silicone pipe for fuel. IIRC, they can handle splashing but not immersion, and given the layout on a Plus 2, when the tank is more than half full, there is the probability that fuel will sit in the pipe for long periods.
I sourced a flexible hose specific for fuel, i believe it is called Ultra flexible fuel filler hose 57mm / 2.25" (from Car Builder Solutions on ebay) - it has spiral wire reinforcement.
Peter
Peter
PeterK - Third Gear
KevJ+2 wrote:Rich,
I fitted a new locking cap (from SJ) last week to my non-locking neck.
At 3 inches difference, I would return it and use a dremel for 5 minutes to produce the slots.
Kev.
I did the same......
got a new locking cap to replace the non locking cap and used a dremel to cut the slots
If someone sold me a six inch ruler and it was only three inches,I'd be disgruntled....
theelanman wrote:KevJ+2 wrote:Rich,
Kev.
I have been doing the same + doing the venting mod. [on the bench] I found it difficult to get the cap [this is not from SJS] to close and had to reduce the depth of a rubber spacer that sits under a central spring [sorry, not able to post a picture currently].. .did you have the same issue ?
1968 Elan plus 2 - project
2000 Elise S1 - Sold
- wotsisname
well guys i did consider cutting notches ...... but decided against it . The new filler neck looks a 'proper job' with stepdowns to the notches and as i'd already faffed around getting the rollpin through it and following that, with plenty of lubricant,managed to pass it through the new rubber panel seal , i decided that was that !
I've found and ordered standard 2.25 " fuel filler pipe so will receive that before the weekend hopefully ..
RichC - Fourth Gear
when i say 'standard ' I don't mean +2 standard pipe but stuff from
www.merlinmotorsport.co.uk
RichC - Fourth Gear
