THROTTLE CABLE CROSS OVER
Finished rebuilding my pedal box and pulled out my old throttle cable and noticed the end was badly frayed and cutting it down would make it just short of what I needed. Being that it was a long weekend, my usual vendors were going to be closed, I took a shot at my local bike store. Seems that the "Campy" brake cable looked the right shape for the pedal side and since I was using Strombergs, all I needed was an open end for the other side. The head was a bit larger than the original Lotus cable, but I thought a jeweler's file would remedy that fairly quickly. But the cable was a perfect fit as it was. The shoulder under the head was just the right diameter and slipped in the throttle pedal bar, and the head could be filed down a bit, but works as it. The cable would not slip out and sits inside the pedal bar as securely as the original Lotus cable. So I figure I would pass this on if anyone else finds themselves in a pinch. Plus the cable costed me only10 bucks and slides into the original cable housing like it was made for it. Not a bad quick fix on a long weekend lol.
- gearbox
I buy tandem bicycle rear brake cables, and bulk housing with additional ferrules. Also use the curved aluminum tube for Z brakes to route the cable over to the carbs on a LHD car. And yes, a little filing on the end of the cable make things work together nicely.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
Mountain bike brake parts before the went all hydraulic. Old tech now, but a good bike shop may still have some stashed away.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
26-4889
50-0315N
1964 Sabra GT
- prezoom
They were called a noodle.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
26-4889
50-0315N
1964 Sabra GT
- prezoom
