fuel line in boot
Hello
Last month , I was seeking after the reverse switch on the gearbox ; with your help ( thanks ) i found it , take it off , not an easy job , and rewire it OK . To day , I am seeking after the hole where the fuel line comes in the boot . I took a lot of photos when I dismantled my car ; but no trace of this point . When did I lost it ?????
JC
JC
- diablo
I don't think it comes " in " the boot but under the boot to a fitting in the bottom of the fuel tank.
Is this a +2 or 2 seater?
If it's a 2 seater the pick up on the back edge of the tank points to where the hole should be.
(I don't know who the picture belongs too as i googled it, so i hope they don't mind me using it)
+2 has a Banjo fitting on the bottom of the tank that drops through the floor next to the diff under the back of the car.
Grizzly - Coveted Fifth Gear
Here is where the fuel line passes through the rear bulkhead on my S3 SE FHC. Please note that the spare was just resting on the fuel tank in this photo while I was doing some work on the fuel lines.
'67 S3 SE FHC
'67 S3 SE FHC
Thank you for your answer . Sorry , I forgot to mention my car is a baby S4 .
I shall try to find this hole on the place you suggest , if I don't find it ( perhaps it has been fullfil during the body works ) I' ll do a new one in the most judicious place .
JCL
JCL
- diablo
[quote="Grizzly"]Is this a +2 or 2 seater?
Don't mind at all. Glad to be of help.
Weldon
the dreaded PO himself
- toggle45
