Mechanical fuel pump by-pass
PostPost by: Heuer » Tue Mar 29, 2016 4:19 pm
I want to by-pass the mechanical fuel pump but I am having difficulty finding a 5/16" female to 1/4" female adapter. Anyone know of a source, web site or part number of something suitable?
Elan S4 DHC
E-Type S1 OTS
E-Type S1 FHC
Heuer
PostPost by: dougal9887 » Tue Mar 29, 2016 7:14 pm
Are you trying to join something up to the 1/4" nylon fuel pipe? If so what?
Dougal.
dougal9887
PostPost by: Heuer » Wed Mar 30, 2016 9:13 am
I want to join the nylon fuel pipe to the braided pipe going to the carbs by-passing the mechanical fuel pump. I am planning to use an electric pump but want to keep the mechanical pump in situ to easily revert back to standard. I have had three mechanical pumps fail, one original and two new - the last installed in September and it looks like the diaphragm has failed after being left standing over winter. My concern is if I leave the pump in circuit fuel could leak into the block.
Can't seem to find an adapter both of which have the same thread, sizes I was referring to were the nuts.
Elan S4 DHC
E-Type S1 OTS
E-Type S1 FHC
Heuer
PostPost by: oldchieft » Thu Mar 31, 2016 8:03 pm
why do you need to by pass it?
In the past I have run an electric pump after the mechanical to prime the float chambers on a Ford x/flow with twin DCOE's
Just press a switch to prime then run as normal after.
Jon the Chief
oldchieft
PostPost by: dougal9887 » Fri Apr 01, 2016 6:47 am
To my knowledge you won't find a coupling suitable for the existing internal compression nuts used at the fuel pump.
I used a 1/4" compression ? 10mm hose tail to connect the 1/4" nylon to 8mm braided hose.
https://www.bes.co.uk/products/071.asp?EPBOE=#8991
Dougal.
dougal9887
PostPost by: Heuer » Fri Apr 01, 2016 2:37 pm
OK, thanks. I checked the mechanical pump and the diaphragm is in good order so I have left it in circuit besides it probably acts as a fuel pressure regulator to some extent.
Elan S4 DHC
E-Type S1 OTS
E-Type S1 FHC
Heuer
PostPost by: Quart Meg Miles » Fri Apr 01, 2016 9:34 pm
Heuer wrote:OK, thanks. I checked the mechanical pump and the diaphragm is in good order so I have left it in circuit besides it probably acts as a fuel pressure regulator to some extent.
Oh no it doesn't, it increases it! If you put two pumps in series you need a regulator before the carbs.
Jon, I'm surprised you put the electric after the mechanical; my problem is getting the petrol from the tank to the engine bay.
Meg
Quart Meg Miles
PostPost by: oldchieft » Sat Apr 02, 2016 1:46 pm
Quart Meg Miles wrote:Jon, I'm surprised you put the electric after the mechanical; my problem is getting the petrol from the tank to the engine bay.
It was a low pressure SU pump, same as fitted to Moggy 1000, so I mounted it in a similar place.
But you can do the same with a high pressure pump, like the old Mini mounted at the back.
It worked find, as it was a Morgan that did not get much running and built in priming was handy.
Jon the Chief
oldchieft
PostPost by: jk952 » Sat Apr 02, 2016 7:36 pm
Meg,
There is always the $7 solution for priming, the outboard motor fuel tank type primer...and worked great again just today for my after winter first start-up....
image.jpeg and
Jack
jk952
