Weber Throttle return Spring comes out.....
Excellent solution Phil! What size did you get?
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
The washer is #4 & the Starlock is 3/32", but I did put a 3/32 drill through it as the spring wire is .103".
Here's a close up:
I had to buy 50 starlocks, do you want a pair & a washer for your car?
Easiest way to put the starlock (pushnut) on is to "stick" it to a small socket (e.g. 1/8" AF) with grease & push it on.
Here's a close up:
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Phil, I would greatly appreciate a pair of these (one for each of my Elans). Once again I owe you
Glen
lotusS2guy wrote:I threaded the length of spring that protrudes and put a nylock nut on. Sorry, I cannot remember the thread spec.
My Starlock washer came off, so following Herb's advice I threaded the end of the spring 4-40 UNC:
To which I cam assemble a #4 SS washer & 4-40 Nyloc jamb nut:
I will solve this issue (with Bill's help)
p.s. I had to buy a good quality die & 100 locknuts, so if anyone else needs this mod send me your throttle return spring & a self addressed stamped envelope & I will do the mod for you...
Phil Harrison
Phil,
like Rohan said bend it,
on my Sprint and all other Elans i have had the end is just bent, no problem. So simple
- alan.barker
alan.barker wrote:Phil,
like Rohan said bend it, on my Sprint and all other Elans i have had the end is just bent, no problem. So simple
Pretty tough to bend & how would you get it out again to remove the barrel to release the throttle cable?
edit: just read what Rohan wrote again:
rgh0 wrote:I just put a slight bend in the end of the spring. Not so much that you cant push it through the two holes with a bit of steering but enough to stop it coming out again.
Still, took a while but my Ford FMA analysis training came in handy....
Phil Harrison
Hi Phil,
the most important is that you have fixed it
Hi TBG,
if you're happy why not.
Sorry to say i'm not soo keen on your Fuel line with soo many joints and damaged connectors
Hi TBG,
- alan.barker
