Weber Throttle return Spring comes out.....
I have the standard airbox with Webers on my Elan. The throttle return spring engages one end in a bracket off the airbox & at the other through one of the Weber throttle levers like:
Over time the return spring keeps on working part way out of the hole in the throttle lever until it is cocked & only through the first hole. The side of the spring then rubs against the carburetor body & the throttle does not close properly.
Anyone have a way to stop the spring from working it's way out?
Would a starlock washer be a good solution:
The spring material is too strong to bend after assembly... maybe a tie wrap?...
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
I threaded the length of spring that protrudes and put a nylock nut on. Sorry, I cannot remember the thread spec.
Herb
26/4618
26/4618
lotusS2guy - Second Gear
Similar to Dave, I used a Marr electrical connector brass inner part (set screw type.) Tried the bending the wire trick but aside from being stiff, is a pain if (when) you want to remove the carbs. When I had the 151 carbs on with the extra boss on the side the spring backed out a bit and fouled the boss causing the throttle to stick open. I like the threading and nut idea.
Jack
Jack
- jk952
Phil, I am not sure what an elec. chocolate block is, I was referring to a household electrical connector produced by Marr, that are readily available I would think, I am in Canada so most of that stuff is common with the US.
I could mail you one if needed, they are cheaper than the stamp
Jack
Jack
- jk952
jk952 wrote:Phil, I am not sure what an elec. chocolate block is, I was referring to a household electrical connector produced by Marr, that are readily available I would think, I am in Canada so most of that stuff is common with the US.
Jack
I think the term chocolate is the common English name for:
Thanks for your kind offer, I'm going to Lowes this evening, let me see if they do them, or if they look at me like a Martian (like they do when I ask about Taps, Torches or Hose pipes...)
It's nice to have options!
Phil Harrison
I cut off the inner end of a brass UK domestic electrical pin complete with its screw. This fixes on the free end of the spring spigot. Works well. Similar to the chocbox connector above.
Malcolm
Malcolm
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
A neat solution would be to drill a hole at the end and install one of these but the metal might be too small.
If it works, however, be sure to use a washer between the clip and throttle piece.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
OK, another way to skin the cat: assuming you have 1/4" or so of protruding throttle return spring and can't find a suitable starlock washer, how about purchasing a small spring that fits tightly over the return spring? Essentially, a tiny version of the spring collar in the picture below. I think this would work better than a tie wrap.
Nick
Nick
elanner - Fourth Gear
gjz30075 wrote:A neat solution would be to drill a hole at the end and install one of these but the metal might be too small.
Way too small for one of these Greg, but you might get away with a small hole, say .040" or less & safety wire.
Phil Harrison
Users browsing this forum: tonyabacus and 43 guests
