Back from a refurbish
Sending them off to Paul at Weber-carbs for a little bit of magic!
Ray S4 fhc
Ray S4 fhc
- Oldthumper
I really hope not Russ,I don't think the bank balance could take it!
Mind you, my son does seem to be getting very serious about his girlfriend,so who knows!
On a more serious note,I was rather surprised,to put it mildly,that when I removed the air box front, I found that the backplate and trumpets were only held by six nuts and clamping washers.Not quite what I expected to find after an ?18k rebuild!
I am not sure how much setting up the carbs will need when returned,but one of my local garages races an Anglia with twin Webers and has offered help if needed.
If not I shall be looking for a good rolling road/tuning specialist in my area. If anyone has any suggestions I would be most grateful.
Ray S4 fhc
Ray S4 fhc
- Oldthumper
I certainly hope not Phil. I suspect that they lost the originals and just couldn't be bothered to look through the disorganised piles of parts at FS.I would have expected to see nice new nylon nuts as well,but in their infinite unquestionable wisdom,they fitted the old ones.
Peeved? More than a little!
Ray S4fhc
Ray S4fhc
- Oldthumper
That looks a bit better!
- Oldthumper
Rebuilt Webers fitted this morning,and after what seemed like ages for the electric pump to fill them,fired up beautifully. Tick over needed adjusting of course,and I think a little fine tuning will be needed, but a quick spin round the block was an absolute revelation. The car pulled strongly and without hesitation,from cold,and the change in power and response was quite amazing. I just have to be more careful in the wet,as I'm used to having to apply quite a bit of throttle to get it moving,and that now has the wheels scrabbling in the wet!
Thanks to Paul at Weber-carbs.co.uk. (No connection)
Quite expensive perhaps,but money very well spent!
Ray S4 fhc
Ray S4 fhc
- Oldthumper
