Fuel Pipe Pump Connections
On my Elan restoration I am using the standard glass bowl type fuel pump. Does the black nylon pipe from the fuel tank connect straight to the pump or should the pump be fitted with a metal tail pipe and then connected to the tank pipe with a short rubber hose? Also on the carburettor side, should the pump be fitted with a tail pipe?
Currently, my pump only has union nuts fitted on the outlets.
- William2
Mine is connected as your second option. Short rubber pipe to metal tail pipes at both inlet to and outlet from the pump.
1965 Elan S2 (26/4726)
2002 Elise S2 (now sold )
1970 Scimitar GTE
1970 Scimitar GTE
- Geoffers71
As above....plastic pipe into pump (with olive) and short metal pipe out (with olive) and fuel pipe connected.
