Throttle linkage
I have a pair of Weber DCOE 40 151's ,and a pair of K@N air filters.Car is a 1968 plus 2.
I have the original throttle cable.
It seems that I will need a linkage to connect the cable to the carbs.
I'm not sure why this is the case,and what linkage I need.I can see several different types on Eurocarbs website.
The guy who rebuilt the carbs said he preferred a Magard linkage,but these are no longer available.
Dave
Dave
- alfadave
Not sure if there is a question here but for my dual 45 DCOE setup I'm using the linkage sold by RD Enterprises here in the states. It appears to very well made and not as clunky looking as the old Magards. I've attached a picture as fitted to my Europa.
- arcangel
Really,I'm not clear in my mind why these linkages are needed in the first place?
I can see some cars with them,and some without.
They don't seem to be an original fitment.
If they are needed there seem to be several different alternative layouts,and again I'm not clear on my options.
Dave
Dave
- alfadave
Dave,
It all depends on if you are going to keep the K&N's or put the original air box back on. With the K&N's you will need something like a Magards as the original air box has a bracket on the back to take the throttle cable.
I would have thought QED have something if you are keeping the K&N's. One of the usual suspects Matty, SueM or SJS should be able to help if you are going back to original.
K&N's are quite noisy but it depends what you want from the car.
Here is a pic of the original.
- elanman999
John,
thanks for your reply.
The Magard type linkages do seem to be a lot of ironmongery to replace a simple bracket.
I would prefer the original type air intake to feed cold air into the engine,so will head that way.The K@N's came to me by chance.
The throttle levers on my carbs are the wrong type,and foul the manifold "bridge" between 2 and 3.
Looking on Webcons site,I think the ones I need are 4504 800 700
and 4504 800 500.
Can anyone confirm that is correct?
Dave
and 4504 800 500.
Dave
- alfadave
Dave
A thought ran through my mind,you do have the misab plates in place?
Dave,
I can't help with weber part no's but I'll take some pics of the linkage parts tomorrow to give you some idea of size.
I should also say that it is not unheard of to have to cut some clearance in the webs between the chokes when fitting an after market throttle linkage.
- elanman999
Dave,
Here some pics of the levers. Unfortunately I had forgotten that I had modified the one that takes the cable barrel. It was 35 years ago and I can't remember why.
- elanman999
For the barrel I just picked up some brass screw cable ends from the auto shop and adjusted the holes through it with a drill. Couldn't easily find one her in the US.
- mbell
mbell wrote:For the barrel I just picked up some brass screw cable ends from the auto shop and adjusted the holes through it with a drill. Couldn't easily find one her in the US.
What are they please- I don't quite get your description. Which shop?
Another lost Brit.
RogerFrench - Fourth Gear
Listed as "Help/Cable stop clamps assortment" doorman 03336 from most chain auto stores.
Largest one is snug fit in the standard lever setup, I just used drill to increase the whole diameter. One side to hold casing, one just big enough to slip the cable end through.
- mbell
