Dellorto Carbs
PostPost by: Hongokongo » Wed Sep 24, 2014 5:58 pm
I have a car with S.U. carbs, and you have to fill the top with thin oil so the dampers can work.
Do you have to put oil in Dellortos, I see there is no air hole, so I'm not sure.
Hongokongo
PostPost by: elancoupe » Wed Sep 24, 2014 7:50 pm
No oil in Dell'ortos.
elancoupe
PostPost by: Chancer » Wed Sep 24, 2014 10:26 pm
Are you thinking perhaps of Stromberg carburettors?
In which case yes, the dashpot needs to contain a certain quantity and grade of o?l.
Chancer
PostPost by: Hongokongo » Thu Sep 25, 2014 8:54 am
No, definitely Delorto's, but I also have an MG with SU's, and they do need oil in the dashpot.
Hongokongo
PostPost by: RogerFrench » Thu Sep 25, 2014 11:57 am
Dellortos are not constant depression carbs with sliding air valves, and therefore dont have dampers that need oil.
RogerFrench
