Stromberg Low Speed Air Screw
PostPost by: peterexpart » Fri Apr 04, 2014 7:48 pm
Does anyone have any suggestion of a starting point for the Slow Speed Air Screw on the Right side of the CD175 Carbs. They were fully removed when I obtained the car and I need an idea of approx. how far the should be Screwed In or Out as a starting point.
PeterExpart
New Forest National Park
Hampshire UK
peterexpart
PostPost by: 69S4 » Sat Apr 05, 2014 6:35 am
The short answer is all the way in (and lightly seated). It's not supposed to work as an idle mixture screw in the way it does in many motorcycle carbs but to provide some sort of "offset" when you're running in a new engine. The Lotus manual says "minor" adjustments can be made with them but I've never got close enough with mine to get to the minor adjustments stage.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69S4
PostPost by: peterexpart » Sat Apr 05, 2014 9:39 am
69S4 wrote:The short answer is all the way in (and lightly seated). It's not supposed to work as an idle mixture screw in the way it does in many motorcycle carbs but to provide some sort of "offset" when you're running in a new engine. The Lotus manual says "minor" adjustments can be made with them but I've never got close enough with mine to get to the minor adjustments stage.
Thank you Stuart I will give that a try
PeterExpart
Hampshire UK
peterexpart
