Throttle Cable Fittings
I'm embarrassed to admit that I've lost the cable guide that goes into the DCOE throttle lever, Weber p/n 45048.007. Now that I have the carbs reinstalled I can't start the car!! Does anyone know where I can get a replacement? It's the little cylindrical piece of approximately 9.5mm diameter by approximately 11.5 or 12mm long that the throttle cable sheath butts against and through which the cable itself passes on its way to the air cleaner back plate mounting point. I can't find this part in the Lotus Elan parts book nor in the Weber Tuning Manual. Can anyone help? Thanks.
'67 S3 SE FHC
'67 S3 SE FHC
If you mean the "throttle barrel - screwless nipple" then Qed have them look on their website under carb - ancillaries
Sorry I couldn't link to it.
'72 Sprint
'72 Sprint
- richardcox_lotus
Thanks, Richard. That's the part. A costly mistake, my losing the original!!
'67 S3 SE FHC
'67 S3 SE FHC
I've adapted ferrules purchased from Flanders cables (flanderscables.com) with good effect, as well as made them from scratch from aluminum bar stock and a drill press. I see Flanders is now stocking the slotted stepped down ferrules, which should make it pretty straightforward.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
Oops. Misread your post. Looks like you were referring to the "throttle barrel" pivot. That can be made from steel bar stock pretty easily with nothing more than a drill press and a hacksaw. The one I made from an old bolt is still in place 24 years later!
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
john.p.clegg wrote:Would this be the cable adjuster?
http://www.ebay.co.uk/itm/MTB-BIKE-BICY ... 3388561a04
No, John. It's the item second from the bottom at the QED website http://qedmotorsport.co.uk/qed-shop/lotus-twin-cam/carb-ancillaries.
'67 S3 SE FHC
'67 S3 SE FHC
Possibly. The proportions look slightly different and there are no dimensions listed but it's certainly a lot cheaper than the one from QED!!
'67 S3 SE FHC
'67 S3 SE FHC
Just search Fleabay for split nipple...
Also amazon etc.etc.
This is the QED item - http://qedmotorsport.co.uk/qed-shop/lotus-twin-cam/carb-ancillaries/throttle-barrel-screwless-nipple
At 20 GBP it has to be the most overpriced item of hardware I have ever seen!
I bought one this spring from Matty, it was certainly cheaper than that.
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Ok. I took the advice on the Forum and hacked up a bolt (actually a lag screw as it had a smooth diameter above the threads!) - hacked being the operative word here. I have a drill press but nothing to hold the workpiece except visegrips. A hacksaw and Dremel and a needle file completed the tooling. I will probably try a better version but this one will allow me to try and get the engine running again.
'67 S3 SE FHC
'67 S3 SE FHC
