Elan S2 - how to remove airbox?
Mark,
Assuming you're talking about the airbox over the Webers then, yes, once you've removed the bolt from the back (it fits through the cable-supporting bracket base) the front cover does pull off. But it may have been fitted with a sealant on the rubber face which is sticking it to the backplate. Then you'll have to dig a lever in somewhere to slowly prise it free.
It you are talking about the intake filter housing then it is always a battle as it is a metal to metal joint like a paint can (in England anyway) once the wing-nut has been released. Plenty of rust release fluid and brute force but watch the brackets attaching it to the bodywork.
Meg
Users browsing this forum: Lucifer and 28 guests
