Electric fuel pump location
PostPost by: Jaybee » Sat Apr 27, 2013 6:10 pm
Couldn't seem to find a lot of info on pump location options on the site so here's mine. Although it sits behind the tank board it's also below the removable boot floor. So the non standard pump and filter can't be seen at either end of the car. John
image.jpg and
Jaybee
First Gear
First Gear
PostPost by: andyhodg » Mon Apr 29, 2013 7:18 pm
Hi John
Is that photo of a 2 seater elan or +2?
Andy
andyhodg
PostPost by: Maulden7 » Wed May 01, 2013 8:32 am
All the electric pumps that I am aware of - with the exception of the old SU type - are "pushers" & not "pullers" & hence should be fitted as close to the tank as possible.
Maulden7
PostPost by: Jaybee » Sat May 25, 2013 11:51 am
Day it's a +2 thanks john....
Jaybee
First Gear
First Gear
PostPost by: Olympicblue » Sat May 25, 2013 8:05 pm
Maulden7 wrote:All the electric pumps that I am aware of - with the exception of the old SU type - are "pushers" & not "pullers" & hence should be fitted as close to the tank as possible.
If you search a puller pump, give a look to HUCO fuel pumps : http://lewysco.com/catalogue/1415Pompes ... %20ndl.pdf
They have puller version.
As say a friend : it is reliable, because it is used on motor boat !
Damien
Elan Plus 2 S130/5 1974
Olympicblue
First Gear
First Gear
PostPost by: Jaybee » Sun Oct 20, 2013 5:10 pm
Sorry for delay yes it's a +2 john
Jaybee
First Gear
First Gear
PostPost by: mbell » Mon Oct 21, 2013 7:30 pm
On my +2 the pumps been bolted to side the pedal box (RHD).
Looks like the pump available from Rdent. It has been fitted with a 90 degree elbow between pump and filter. So that the filter is running along the bulk head and joins nicely to the fuel hose.
