Leaking tank or evaporation?
Hi all!
I filled the tank on my +2 -72 in december and measured the petrol level down the filler neck with a stick. 3,5 months later the level had dropped 5 cm (2 inches). No driving of course Is this a leak or could it be evaporation? Seems like a but much to evaporate to me?
For what I can see, without having tanken the tank out, I can find no signs of leaks anywhere.
Any ideas?
Jens
Elan + 2 -72
Sweden
Any ideas?
Jens
Elan + 2 -72
Sweden
- jensmartin
Because of the size of the vent pipes, fuel in a Plus 2 evaporates a fair bit. It also smells a fair bit!
I'd bet on it being evaporation, if you have a leak it should be pretty obvious - stains on the garage floor, moisture around the tank, top of diff etc.
Some plug the vent tubes when not it use - do a site search for whiskey corks and you'll see some discussion about this very matter!
Robbie
Robbie
Hi Jens,
I agree that it is evaporation rather than a leak.
Question:
Why did you fill the tank if you were not going to use the car, apart from the waste from evaporation the octane level of the fuel will have deteriorated by now.
Here's an interesting article from BP regarding storing fuel. It suggests leaving the tank half full if the car is not to be used for a while and that fresh fuel should be added before starting the engine.
Question:
Kindest regards
Alan Thomas
Alan Thomas
Very interesting reading Alan! Thanks alot. So probably it's not a leak I have.
The BP document states that after 5 week 15% of the volume is lost! Seems to explain my lost two inches of fuel.
I've been learned that you should let the tank be full to collect less water when stored for a long time, this seems to be wrong.
Best regards
Jens
Best regards
Jens
- jensmartin
My +2 uses more petrol when stood still than when driving....
Evaporation......
Would be more acceptable if the huge breathers actually allowed me to FILL the tank (tank evaporates less the fuller it is).
So, my solution is to drive it as much as possible.
It's more economical that way....at least that's what I tell 'er indoors......
Lyka till,
Peter
Evaporation......
Lyka till,
Peter
'73 +2S 130/5
'73 +2S 130/5
peterako - Fourth Gear
Evaporation
I am planning on newer teflon lines combined with steel or... along the length or backbone. As well as fuel injection clamps.
Rubber does allow evaporation and so do the +2's vent system.
There are posts to using a modern fuel breather vent (internals of a gas cap) While using the flip lotus external. You need to remove the spring etc. But it has been working on my car.
vote for 1/2 full/empty then fill and start. run empty and fill with fresh fuel
Love your Mother
Earth
Love your Mother
Earth
