fuel check valve
• Page 1 of 3 • 1, 2, 3
I am thinking of best placement for a fuel check valve.
Guess after the mechanical pump but I am not sure if that will disrupt the exact flow required.
So I may end up putting it before the pump!
any thoughts comments suggestions etc... appreciated !
kind regards all
kind regards all
Love your Mother
Earth
Love your Mother
Earth
It seems to be an unusual thing to want to do. How were you going to activate it?
Is it an Elan or is is a Plus2 ?
On an Elan the easiest place would be where the fuel tank joins to the fuel pipe in the boot, same place as it is easiest to fit an electric fuel pump.
Unusual how
What I understand about check valves is that they hold pressure so it does not reverse back to tank
I also understand there will be evaporation from the fuel line, so nothing will be perfect
Does a fuel check valve not hold pressure ?
regards
regards
Love your Mother
Earth
Love your Mother
Earth
Oh, that kind of valve. I see.
I bought one a few weeks ago to use as a non-return valve on my vacuum system. It was designed for fuel (probably diesel) so should be fine for your purpose.
http://www.burtonpower.com/catalogsearc ... turn+valve
I got mine at a local motor parts factors
cool
thanks
why do people not use these
they tend to put a electric pump and maybe a regulator
I guess the oil leak problem is still there, but what else is new
thanks
Love your Mother
Earth
Love your Mother
Earth
For how long to you expect it to hold what pressure and where?
thanks
I loose pressure in three-four days. more than one 8second crank. (if it has been sitting for a month it can take 10 8-sec cranks) guess things get lubricated which is good but i suspect they get lubricated if running too.
probably more frustrating than anything, and I would swap out pump if valves dried and worn out after 44 years?
so this was my thought, a $10 fix
If anybody has solutions, I don't see fuel. or smell it. I don't plug the roll-over vents. and I do have a modern fuel-cap-vent installed in the filler-cap.
I see people have put in electric, and the hand-opperated prime mechanical unit...
the 1969 + 2 does not suffer from lack of fuel it seems
Love your Mother
Earth
Love your Mother
Earth
I think what you are loosing is the fuel evaporating out of the fuel bowls in the carbs. The engine then needs to crank over to refill the carbs. i dont believe adding extra check valvles into the system will make much difference unless the valves in the pump are passing in which case you probably should replace the pump. An electric fuel pump is the easy fix
Float bowl
Makes sense
It seems like an awful lot of cranking for a bowl.
Though I agree an electric pump would solve all
Makes sense
Love your Mother
Earth
Love your Mother
Earth
Webers do tend to evaporate all the fuel out of them after a week or two and hence the long cranking time on a mechanical fuel pump to refill the float bowls. I solved it with a light weight gear reduction starter on my S2 but will be converting to an electric fuel pump (Facet Posi Flow) and an impact cut off switch in the very near future.
- Jeff@Jae
thanks
is a "electric fuel pump (Facet Posi Flow) and an impact cut off switch" if continuing to run the mechanical pump.
i was thinking of having a switch for priming the carb.
but maybe the "electric fuel pump (Facet Posi Flow) and an impact cut off switch" is a better option while removing the mechanical.
outside of oil leaks. any other benefits?
regards
regards
Love your Mother
Earth
Love your Mother
Earth
The simplest solution is that devised by Alex. You fit a primer rubber-bulb pump (from an outboard-motor fuel system) between the tank and the long pipe in the boot. Leave the mech fuel pump as is.
A few squeezes on the bulb primes the carbs if they have been left long enough to evaporate.
hey
thanks
does the fuel evaporate or dribble into engine in the stromberg carbs?
I hate to think it is evaporation (should not that quick) but would prefer to think of loss. I may try a new carb kit seals etc. but wonder if a dab or two of fuel tank glue or epoxy would be a better fix
and would a bulb suffice in the engine as I park reverse under an overhang so I could not access the boot
regards
james s
thanks
regards
james s
Love your Mother
Earth
Love your Mother
Earth
