fuel tank fuel feed bush
Hi Folks
On an original fuel tank where the bolt that hold the fuel feed out banjo is very tight, as is the drain plug, what sort of torque would the tank take if I have to really "heave on it"
sure others have had this problem
thanks in advance 4 any advise
Bob
Bob
- bob_rich
I guess that the amount of weight you can put on the tank fittings will depend to some degree on how thick the 40 year old parent metal is, tanks can corrode on the inside as well as the outside. Maybe a good application of penetrating oil 24hrs. prior to starting will help, also use a good fitting socket.
Paul
- Paul Chapman
