Stromberg needles & jets
I have spent a good deal of time in the archives looking for a solution to my little ptoblem. I have a SE DHC with Strombergs, I had adjustable jets on a pair of NOS that I was using but since I have changed the engine mounts to the correct type for a Stromberg the adjustable jets touch the top of the pedal box area on hard acceleration.
Fitting a used pair of Strombergs I have found the fuel mixture to be to rich running at around 11-1 to 12-1 at idle and not much leaner on partial throttle so I obviously need to replace the needles but I am unsure which would be best to use, looking through the archives it seems that B1G, B1y and B2AR are used but there seems to be no reason for one over an other. I have removed the needles and set them as per the manual (these are non adjustable) the car runs really well and has plently od power it just runs to rich.
I am thinking I need to replace the needle and was hoping to try and get some of your collective wisdom as to which ones I should be using, furter should I also replace the jets or move them a little higher in the body to try a lean off the mixture. Needless to say that the float levels have been set, both carbs cleaned out and new gaskets float valves and diaphragms have been fitted.
Looking forward to hearing what others think?
Tonyw
Tonyw
Second childhood? no just an extension of my first.
- Tonyw
Hi Tony. If you haven't replaced the jets that's worth doing. They do wear and the wear patterns were visible in my old ones. Measure their existing position before you knock them out so at least you've got a reference point. When I did mine I couldn't get much info on what the exact height should be but I've at least got adjustable needles which will take up a bit of positioning slack. There are differences between the profiles of the three needles you mention and they are the usual suspects. I spent ages pouring over the differences in a whole range of needles (same problem, running rich) and then went with what was in there already (B1Y). New needles and jets made a big difference.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
Hi Tony,
If you've searched already you will probably have come across the spreadsheet where you can compare the various needles but just in case you haven't here it is again......
S4 DHC
S4 DHC
- oldelanman
