Fuel Guage
PostPost by: Tonyw » Fri Apr 06, 2012 2:22 pm
Hi all,
Just trying to put the finishing touches on my Elan SE and I have a problem with my fuel guage, I have an FG2350/71 guage which requires a 0-90 ohm sender and these are not available so consequently my fuel guage is not working, I have a 6 hole sender that is 240 - 30ohms so I was wondering if anyone knew what car the fuel guage came out of that fits that particular sender? I do have a voltage stabiliser which provides a very steady 12.2volts. I thought it might be easier to get a guage to fit the sender rather that a sender?? any suggestions?
Thanks in advance.
Tonyw
Second childhood? no just an extension of my first.
Tonyw
PostPost by: pereirac » Fri Apr 06, 2012 3:41 pm
You can get a replacement sender from Axminster Specialist Panels. I have one of their fuel tanks and the quality is excellent.
http://andywiltshire.com/Lotus%20Elan%20Tanks.htm
Carl
Carl
72 Elan Sprint
87 Excel SE
97 Alpina B10
http://www.lotuselan.co.uk
pereirac
PostPost by: Tonyw » Sat Apr 07, 2012 9:59 am
Carl,
I wish... Andy's site specifies the fuel sender as unavailable I should have got one when I first saw the site...............
Tonyw
Tonyw
PostPost by: john.p.clegg » Sat Apr 07, 2012 11:21 am
Tony
" I do have a voltage stabiliser which provides a very steady 12.2volts."
shouldn't that be 10 volts
John :cry:
PostPost by: Tonyw » Sat Apr 07, 2012 12:35 pm
John,
Yes you are correct 10.2 volts it is.
Tonyw
Tonyw
PostPost by: badback » Sat Apr 07, 2012 12:48 pm
Tony
Have you tried P Matty for the 0-90 ohm sender unit
badback
First Gear
First Gear
Users browsing this forum: pcarew and 11 guests
