Weber DCOE linkage advice needed
Hi all, I have a pair of 40DCOE151 for my new motor. The weber do not have the linkage that mates the 2 crabs together. I think this is the part i need (see link)
http://www.piercemanifolds.com/product_p/pm3719.htm
and maybe this
http://www.piercemanifolds.com/product_p/lt5000.htm
Can some please confirn which parts i need? I see a lot of cable options, any advice is appreciated.
James
and maybe this
James
holywood3645 - Fourth Gear
Just to clarify, the first one is correct.
The second one you would only use if :-
a). You wanted an extra return spring to the one already built into each of the carbs, or
b). If you wanted to do away with the internal return spring in each carb.
(I wouldn't advise it, but some people do). There have been a few very minor instances where an internal return spring has broken and prevented the throttle spindle from closing, but we are talking 000's to 1 chance.
elans3
elans3
Previous :-
Elan S3 DHC SE SS 1968,
Elan S3 DHC S/E 1966
Elan S3 FHC Pre-Airflow 1966
Previous :-
- elans3
James will only need the big throttle return spring above, if he's using the original airbox,as t'other end of the spring locates in the bracket that's part of the airbox rear pan.
elans3
elans3
Previous :-
Previous :-
- elans3
Users browsing this forum: Fred Talmadge and 20 guests
