fuel pressure check with EFI
HI Folks
I asked the atatched question under the modifications forum and did not manage 2 get a reply so I though I would try it in this forum as I know a few folk have fitted EFI on their twinks so here goes again
Fitting an EFI to the twink. Just a simple question ( I hope) can I read the fuel pressure at the blanked off port on the fuel pressure regulator?? I assume the pressure should be read on the output side of the fuel rail
the attached note explains the question fully
thanks in advance 4 help
Bob
Bob
- Attachments
- Fuel%20Pressure%20Regulator%20Connections2.doc
- (431 KiB) Downloaded 411 times
- bob_rich
Bob
Saw your earlier posting and did not know the answer,still don't but the reading should come from the fuel rail (pressure) side of the regulator not the return,if the two inputs (as denoted by arrows) are common it should do the trick but you'll have to see if they are commom...
bob_rich wrote:HI Folks
I asked the attached question under the modifications forum and did not manage 2 get a reply so I though I would try it in this forum as I know a few folk have fitted EFI on their twinks so here goes again
Fitting an EFI to the twink. Just a simple question ( I hope) can I read the fuel pressure at the blanked off port on the fuel pressure regulator?? I assume the pressure should be read on the output side of the fuel railthe attached note explains the question fully
Bob,
Correct - pressure regulator is on the return line.
The gauge can be fitted as per your photo. My regulator came with a gauge fitted.
The picture shows my set-up:
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
bcmc33 - Coveted Fifth Gear
