"pancake" ZS air filter question
Hello folks.
I've been running a set of 'pancake' air filters over a pair of ZS carbs on a federal S4.
I occurred to me one day when I opened the bonnet how hot it gets in there, and that perhaps the motor is not so happy breathing all that in through those local pancake filters. Am I doing the motor an injustice? I've tried to use the stock airbox in the past, but for reasons that are beyond me, the fit was difficult, i.e., the front opening would rub hard against the wheel well, and I just don't feel like beating that problem to death (I'd probably rather fabricate a straighter airbox).
Are the pancakes a no-no, or an acceptable alternative?
1970 Elan S4 DHC 45/9780 1972 Triumph TR6
1958 Bugeye Sprite 1967 Triumph Trophy 650
1991 Ducati 900ss 1989 Honda GB500
- Chrisrich
Chris,
When I got my Elan, it had 2 K&N filters fitted directly to the carbs. Being a disciple of as much cold air to the engine that I can get, along with the "boost factor" you get with the air filter pointing forward behind the grille, they had to go.
I too had the problem with the air intake to the air box hitting the inner fender well. So, I cut a wedge out and re-oriented the tube portion to point where I wanted it, and re-glassed it back together. A piece of flex tubing and a home made double pivot adapter was made to fit between the flexible tubing and the cone shaped filter. I used a Green Filter rather than the usual red K&N, because my car is green. But, they are essentially the same. Across the pond, cliveyboy makes a similar style adapter, but I have a lathe and enjoy making chips.
Rob Walker
26-4889
Rob Walker
26-4889
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
