Air Filters that fit OE canister
Try http://www.wixeurope.com/catalogue/Resu ... eField.y=8.
Click on blue part number, then All Applications.
This is what I have fitted to my S4.
Colin
Colin
urr333 wrote:Can anyone advise what air filter element fits the original canister. I have been supplied a FRAM CA614PL which is 2.5 inches deep and too thick to fit without distortion.
'68 S4 DHC
- fatboyoz
I had the same problem....did you get it from Sue Miller ?
I found that if you trim off the inner lip on each side and leave out the original rubber rings from the can it will just about fit.
S4 DHC
S4 DHC
- oldelanman
Thanks for your input. I did get it from Sue and trimming the inside edge was her solution also so I will give it a go!
Colin, I had a look at the website you suggest and it seems that the unit they offer is 60mm high (2.4 inches) so I guess must have similar problem.
Thanks again
Ted
Thanks again
Ted
- urr333
Mine was tight fit also and from Paul Matty.
It is correct though; see Fram website:
http://www.sogefifilterdivision.com/cat ... AM&lang=GB
Jason
Jason
Jason1 - Coveted Fifth Gear
Paul Matty's told me the same, that's all that's available and they are slightly taller.
That is very neat cutting Roger- what did you use? I tried with a craft knife but made a pigs ear of it!
Robbie
oldelanman wrote:I had the same problem....did you get it from Sue Miller ?
Robbie
Ted,
I put a vernier caliper across the filter. It measures 2.35" before squashing the seal.
Colin.
Colin.
urr333 wrote:Thanks for your input. I did get it from Sue and trimming the inside edge was her solution also so I will give it a go!
Thanks again
Ted
'68 S4 DHC
- fatboyoz
Robbie693 wrote:That is very neat cutting Roger- what did you use? I tried with a craft knife but made a pigs ear of it!
Well if you had persevered you may have achieved a silk purse
I can't recall what I cut it with but I do remember I did it in the kitchen it was either a carving knife or a serrated bread knife - something with a longish blade so I could cut from the outside edge and not try to work from the hole in the middle. The picture below shows how much difference there is between the Fram and the original elements
It's only really the look of the thing that warrants cutting the filter down, if the two halves of the can don't meet it doesn't affect the efficiency of the cleaner as the resulting gap round the circumference is on the "dirty" side of the element.
S4 DHC
S4 DHC
- oldelanman
Rodger,
Your photo does make clear why it is such an issue. The point you make re the gap is true but the fixing stud on the lid does not appear thru' the hole until the lid is well inside the canister!
As I do not have the mounting points for the Lotus kit I'm thinking of giving up and switching to a K&N cone which I think I will be able to install more simply.
Ted
Ted
- urr333
oldelanman wrote:Robbie693 wrote:That is very neat cutting Roger- what did you use? I tried with a craft knife but made a pigs ear of it!
Fortunately I practised on the old one and, after cocking it up, just installed the new one as it was, reasoning it was sealed anyway as you say. I managed to get the wingnut on without crushing the filter.
Robbie
