the old 4 star / unleaded dilemma
Having run on 4 star up to now & having looked at the archives here I am thinking of using the shell optimax variety for a bit. Ipickup 4star in my red 20 litre gerry can .(I'll miss the smell of 4 star.)
probably won't do more than a thousand or so miles in the summer .
what's the general consensus folks? straight optimax ?
As I've the low compression head I'm not expecting to have to adjust the timing advance much & it isn't revved much at all
I gather that the valve seats are not that prone to recession and that in the states they,re quite happy using unleaded ...
RichC
RichC
RichC - Fourth Gear
Ever since unleaded fuel became the norm, I found that unleaded plus the lead substitute from Redex, was a MUCH better fuel for my Elan than the crappy 4-star that was around.
I hadn't realised that you can still get anything called 4-star anywhere.
kstrutt11 wrote:For many years now I have used regular 95 octane unleaded and an addative with no problems whatsoever
Same here. I've got the cylinder head off at the moment (still sorting water pump ) and a quick first inspection shows everything as it should be - no seat damage etc.
I've not had any problem with ignition advance either but that's because the replacement 43D distributor that was fitted years ago came with 7 degree advance weights. That makes 14 degrees of crank advance + 9 degrees static = 23 degrees total. The Stromberg engine should have 33 max (according to Wilkins) so it's not surprising really.
I thought it would be a simple task to change springs and weights to get it back to std but the http://www.distributordoctor.com/ didn't think it was possible (although I seems to have missed out on the reason why). If it really isn't maybe a file and a protractor may get me part of the way there.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
Repeating what I've posted before - I use Tesco 99 octane stuff plus a dose of additive to make what I think is the 101 octane that the engine was designed for.
Never had a complaint.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
bcmc33 - Coveted Fifth Gear
