Early Air boxes and backing plates - lots of Wide Photos
• Page 1 of 3 • 1, 2, 3
My good friend Lance called today and was asking about air boxes and backing plates. I don't have any of the Sprint type so maybe someone else will post some photos of them, Tim may have done so before but I don't remember it. anyway I am glad I was around as I found more differences than I knew of. THe Stromberg airboxes are totally different but I was un-aware of the early weber boxes and backing plates were different until I looked closely at them side by side. one set is from 26/4020 and the other is a bit of a mystery but I believe that it's from 45/7334 so take a look and see if you can help with other changes.
Gary
no lable - edited to fix my poor discriptions per Bill in the 3rd post, hope thats better, there is enough confusion around Elans
![Image](http://s248.photobucket.com/albums/gg179/landofooz/1253651494.jpg)
26/4020 top and 45/7334 bottom
![Image](http://s248.photobucket.com/albums/gg179/landofooz/1253651495.jpg)
![Image](http://s248.photobucket.com/albums/gg179/landofooz/1253651496.jpg)
![Image](http://s248.photobucket.com/albums/gg179/landofooz/1253651499.jpg)
![Image](http://s248.photobucket.com/albums/gg179/landofooz/1253651500.jpg)
![Image](http://s248.photobucket.com/albums/gg179/landofooz/1253651502.jpg)
![Image](http://s248.photobucket.com/albums/gg179/landofooz/1253651504.jpg)
![Image](http://s248.photobucket.com/albums/gg179/landofooz/1253651505.jpg)
![Image](http://s248.photobucket.com/albums/gg179/landofooz/1253651507.jpg)
![Image](http://s248.photobucket.com/albums/gg179/landofooz/1253651508.jpg)
Gary
Hi Adi
Thanks for the info, I am not sure when it changed but Road draft tubes probably ended in 1965. So does anyone else have a S2 built in late 65 they can check to see if it had the road draft tube and elbow gromet or the air box breather into the cylinder head?
Gary
Gary
elancoupe wrote:My late 66 S3 had a road tube.
Hi Mike
So a September 66 invoice date, which bit of fiberglass does it have, I am wondering if there was a mix and match happening. Or if the air box cover was type 26 or type 36/45 dependent
Gary
garyeanderson wrote:elancoupe wrote:My late 66 S3 had a road tube.
Hi Mike
Gary
Unfortunately, when I bought it, it had the dreaded pancake filters. The current airbox and (now deepened) cover are not original.
- elancoupe
Oh yes now that you menton it I remember, never mind.
I looked it up in the Master parts manual for the S1 S2 Coupe dated 1966 and is states the following:
PL35 Backpate (airbox) except U.S.A. 28 S 021 - S1, S2, Coupe
Thats a Lotus Cortina Back plate!
At the bottom of the page is has
Backplate (air box) - U.S.A. only 26 S 714A - S1, S2, Coupe
PL37 Plate Air box cover B26 S 022
so the fiberglass piece seem to be the same till 1966 sometime, no month listed, still need to do some more diging on this...
Roger is your master parts manual any earlier than the internet copy?
Ok where are you located, my last post seems to say one bit of fiberglass and 2 back plates one for the U.S. and another for everywhere else.
Gary
p.s. - Got a name, I think I'll change mine to "broken record"
Gary
Great photos I never realised there were 2 different versions of the oringinal single bolt air box. My Elan 36/8555 had the 2 bolt version and my 73 plus2S 130/5 has the 3 bolt version. I have looked at lots of the early ones but never had 2 different ones side by side to compare.
you learn something new every day
rgh0 wrote:Great photos I never realised there were 2 different versions of the oringinal single bolt air box. My Elan 36/8555 had the 2 bolt version and my 73 plus2S 130/5 has the 3 bolt version. I have looked at lots of the early ones but never had 2 different ones side by side to compare.
Thank to Lance I put them there "side by each" to get photo's. I didn't know until yesterday and the parts have been sitting in the kitchen for a couple of years right next to each other. Its just amazing the details that I miss when folks don' ask questions.
Gary
Variations? Early air boxes and backing plates read throttle cables are no different than many many many other "early" Lotus parts. (1948 - 1973)
I don't believe you'll ever pin down vin number production/part changes, ( based on everything else I've read on this site. ) We're not driving Porsches.
Eric
Eric
- 1964 S1
Hi Gary
Thanks for the Unit number, Location, and name
Hi Eric
So what is on your 64 S1 for air box cover and backing plate, not many folk with early cars here and you seem to have a fairly origingal and stock Elan.
Gary
Hi Eric
Gary
