fuel injection elan+2
PostPost by: stronghold » Sun Sep 20, 2009 1:23 pm
can any one help me i am thinking of fitting fuel injection does any one know of a DIY conversion
stronghold
New-tral
PostPost by: msd1107 » Sun Sep 20, 2009 3:55 pm
Take a look through these:
http://www.google.com/search?hl=en&num= ... f&oq=&aqi=
David
1968 36/7988
msd1107
PostPost by: stonks » Thu Sep 24, 2009 6:30 pm
There is an ECU called a mega tune / mega squirt, it uses standard fuel injectors which if you made up your own manifold you could use, and it also uses proprietary parts such as vw throttle body, you would have to fit additional sensors such as coolant, air and others but not an insurmountable task.
see here:-
http://www.megamanual.com/megatune.htm#intro
stonks
First Gear
First Gear
PostPost by: tdafforn » Fri Sep 25, 2009 8:22 am
I've got one of these megasquirts fitted, although only running the ignition at the moment.
John Clegg has one fully working
tim
1972 +2S130
tdafforn
PostPost by: jono » Fri Sep 25, 2009 8:43 am
QED do a turnkey kit complete with engine map. Expensive but should be good.
I am going down the jenvey route with Emerald, Omex or similar ECU, QED trigger wheel and other kit such as fuel pump, coil pack etc from a scrapper Ford.
When you look into it fully it's not cheap if you want to do it properly but worth it I think.
Jono
PostPost by: john.p.clegg » Fri Sep 25, 2009 9:44 am
Mr Stronghold
You omit to say where you are?......I am tuning the fuel injection fitted to my plus2 (steep learning curve) and as the rest of the forum knows I'm not one to throw my money about (either that or i prefer messing around to see what I can do) .....Megasquirt is a self assembly kit (or you can purchase ready built/programmed) and as for the rest....crank sensor,fuel pressure regulator,high pressure pump,throttle bodies etc,etc,etc. can be picked up quite cheaply (fleabay,breakers yards etc.)
If you want I can post some piccies?
John :wink:
PostPost by: niallf » Fri Sep 25, 2009 12:07 pm
Don't forget about fuelling needs. The +2 tank isn't designed for a pressurised injection set-up. The Spyder Zetec conversion uses a Spyder fabricated 1L swirl pot downstream of the tank and an in-line Bosch fuel pump, filter and an adjustable fuel pressure regulator. Also there are also new fuel lines (flow & return from the swirl pot) that are run inboard of the chassis. None of it rocket science, but not part of a normal carburettor set-up.
Niall
niallf
PostPost by: ceejay » Sat Sep 26, 2009 10:38 pm
Wolf EFI Hardware - Management - Accessories + More
http://www.wolfems.com/index.html
Locate Your Nearest Wolf Dealer. (Worldwide list)
http://www.wolfems.com/locationindex.html
EFI set up on twin cam engine.
PostPost by: brian wilson » Sun Sep 27, 2009 8:18 pm
Hi CeeJay
A photo of my car engine with throttle bodies!!
Wolf have been fantastic getting the car to run properly on their system, runs really well.
They also supplied all hardware
As a warning to all, be very aware of doing any business with the company that CeeJay got the photo from. Not very reliable or trustworthy in my bitter experience
brian wilson
First Gear
First Gear
