delorto air bleed screws
PostPost by: Over Steer » Sat Nov 08, 2008 8:44 pm
Hey all
My carbs do not seem to be fitted with an air bleed screw. How am I supposed to balance the barrels on the same carb? I don't want to bend the throttle spindles if possible.
any ideas?
Dellorto.jpg and
Jan
1963 23B
1969 Elan + 2
1973 Europa JPS Special
2004 Prep'ed Lotus Exige
Over Steer
PostPost by: alaric » Sat Nov 08, 2008 8:54 pm
Here's some pics of my carbtune hooked up. It's what you labelled as the vacuum tapping - you need to be on the vacuum side of the butterfly valve.
Dellortos with synchroniser - closeup.jpg and
closeup
Dellortos with synchroniser.jpg and
Carbtune and Dellortos
carbtune_on_dellortos.jpg and
Carbtune fitted to Dellortos
alaric
PostPost by: types26/36 » Sat Nov 08, 2008 9:07 pm
The later Delloto's (and Webers) were fitted with adjustable idle air bleed screws (although not in Elan/Europa production) so you just have to go with what you have got, never had any success bending throttle valves myself, in my experience its a bit of a compromise as to where you set one pair carb throttle valves compared too the other.
All you can do is get the best throttle valves position in relation the the other throttle valves.
types26/36
PostPost by: bcmc33 » Mon Nov 10, 2008 12:31 am
From the Des Hammill & Miles Wilkins books it appears that the carbs you have were the early Dellortos fitted to address some European emision regulations (1970/1) that the Webers could not meet. To further improve the situation, Dellorto later produced the DHLA40 emmision controlled carb that Lotus used. This carb can be recognised by the recessed idle by-pass adjustment screws.
Wilkins notes that Dellorto carbs were used on Europa from late 1971 and on Sprints 1972. I guess there?s no way of knowing when the idle by-pass carb was introduced, but my Sprint produced late 1972 has them fitted.
Brian Clarke
(1972 Sprint 5 EFI)
bcmc33
PostPost by: Over Steer » Mon Nov 10, 2008 7:32 pm
Thanks for the feedback,
The carbs were originally on a 1973 Europa Special. There is only a very slight difference on one barrel. The other three are exactly the same. It's not worth risking damaging them by twisting the butterfly spindles.
Thanks for the information.
Jan
1963 23B
1969 Elan + 2
Over Steer
Users browsing this forum: elanner, ericbushby and 21 guests
