Essential and recommended tool for balancing the mixtures
This is with thanks to John P. Clegg for suggesting it to me, cheers John.
It deserves to be wider known.
Buy an Infrared Thermometer and use it to measure the exact temperature of the exhaust manifold pipes an inch or two from the head.
It gives a very good indication of the fuel mixture each cylinder is burning. You can adjust the mixture screws and see the difference it makes to the temperature with far more accuracy than a colortune.
It allowed me to finely balance the mixtures across all 4 cylinders and make a major improvement to a lumpy idle, and so easy to use.
It does not allow for the balancing of the carbs though! Mixtures only.
Maplin have one on special offer for ?19.99 which is where I bought mine; again thanks John for putting me on to it.
You can probably also use it to spot vampires and zombies, then use your finely tuned Elan to run them over and save the world.
Mark.
Mark.
M.J.S - Second Gear
Many thanks Mark,have yet to try it on the tyres,but I believe it does give one a good indication of.......
I have one further tip for balancing the carbs. Many years ago, having tried all the usual methods I started taking out the progression hole blanking screws on the inner two throats and shining a light up the carb throat so as you can see the butterfly plate in relation to the progression holes. You can then use the idle speed stop screw and the balance screw to ensure that both plates are positioned correctly to the same relevant hole. Follow this up by adjusting the mixture screws as per normal. I've found this to be the best method by far.
europatek - Second Gear
Gene
weak cells in batteries?
Tell us more....
Tell us more....
Would this also be useful for checking actual water temperature through the hoses, rather than what's being displayed on the gauge ?
- richardcox_lotus
Great idea boys I did look on E-bay for these devices. There are a number on them with various temperature ranges. Can I ask up to what heat range should I consider when the engine is hot?
- Sarah Ryan
M.J.S wrote:Buy an Infrared Thermometer and use it to measure the exact temperature of the exhaust manifold pipes an inch or two from the head.
Mark.
What temperaturrange (in Celcius) is neccessary to measure the exhaust manifold pipes? 200 degrees? less or more?
Bjorn-Anders, Norway
'95 Caterham Seven Roadsport
'02 Elise Supercharged
ex Europa S2
ex Elan +2S 130
ex Esprit Turbo
ex Caterham SS
Life is too short to drive boring cars
ex Europa S2
ex Elan +2S 130
ex Esprit Turbo
ex Caterham SS
b-havers - Third Gear
