throttle return spring bracket
PostPost by: rdssdi » Fri May 23, 2008 5:03 pm
Has anyone replaced the standard fiberglass air box with 2 K&N air filters?
How did you attach the throttle return spring?
Bob
rdssdi
PostPost by: elansprint71 » Fri May 23, 2008 7:34 pm
This shows (almost!) the bracket on my Dellorto set-up, there is a small hole in the bottom of the bracket which the return spring is anchored to.
Pete.
New radiator 007 copy.jpg and
PostPost by: rdssdi » Fri May 23, 2008 9:42 pm
Although I am running Zenith Stromberg carbs, I like your design. I will have to look at the car tomorrow but I believe I can attach a bracket as you have from behind the casting using longer bolts.
I would appreciate any additional photos or information/suggestions.
Bob
rdssdi
PostPost by: frearther » Sat May 24, 2008 9:27 pm
RD Enterprises has a neat low profile throttle return spring hookup that is more positive than the original layout and does not need the airbox. I don't know if it's available on the right side of the pond or not :wink:
Art Frederick
S2 Roadster, built in 1965, registered in 1966, No. 26/4934
Nothing else of interest at present
frearther
PostPost by: Rob_LaMoreaux » Tue May 27, 2008 12:32 am
rdssdi wrote:Has anyone replaced the standard fiberglass air box with 2 K&N air filters?
Bob
Hi Bob,
Why replace the standard airbox? Except that it is a little too shallow for the #4 weber venturi it is an excellent design. It pulls cool air from the nose where 2 carb mounted filters would get warm air.
I used a K&N cone filter in the nose since the original filter was long gone by the time I got the car. Now that I have the weber engine in the car, I am planning on reshaping the fiberglass box to add more depth in the rear. I can see with a right hand driver that would not be a good option, but with a lhd driver it seems to me to be the best method.
Just my 2 cents and not worth much more than that.
Rob
Rob_LaMoreaux
PostPost by: rdssdi » Tue May 27, 2008 12:27 pm
I have zenith stromberg carbs not webers.
I replaced the air box because I ran out of room in the nose for the air filter. I added one Lockheed brake booster to this already cramped area.
The K & N's were my only option as the Pipercross or ITG filters are too large. At least hat is what I was told. I would have to measure as Piper Cross offers a filter that covers two strombergs and is just under one inch in height.
Anyone attached any of these to a LHD +2 with Zenith Stromberg carbs.?
Bob
rdssdi
PostPost by: Phil W » Thu Jun 19, 2008 3:58 pm
Replaced mine years ago with K & N's from Demon Tweeks (oval). They also supplied a cable mounting bracket.
Phil W
PostPost by: M.J.S » Thu Jun 19, 2008 4:22 pm
Bob
On my car the previous owner has removed what is I assume is the original lower bracket where the throttle cable hooks through, and has then riveted it in place into the backplates of the K&N's. For the top return spring a simple L shaped bracket is bolted through the same plate on which to attach the spring. Simple and not too pretty but it works. I will modify and make it neater when time permits.
Mark.
Throtle bracket.JPG and
M.J.S
PostPost by: rdssdi » Fri Jun 20, 2008 7:24 pm
I was sold the round K & N filters. The front filter contacts the hood (bonnet) and I have removed them in favor of the original fiberglass air box using the trunking and a K & N cone filter in the nose. I have yet to mount the cone filter so I assume as all things lotus are a pain in the &%^$^%& it will be an ordeal.
Of course this was discovered after I designed and had fabricated a return spring bracket that worked great.
So it goes.
Bob
rdssdi
