Original air filter
PostPost by: Vanden Perre » Wed Apr 23, 2008 5:50 pm
Hello,
Would one of you have some pictures of how and where exactely the original air filter (frying pan) was fixed in the nose of the Elan?
Would be interesting as I want to instal it to my S3.
Thanks.
Olivier
Vanden Perre
PostPost by: cabc26b » Wed Apr 23, 2008 11:05 pm
there should be a couple of holes in the nose where it bolts ( I think ) through
PostPost by: Leo Leentvaar » Fri Apr 25, 2008 1:14 pm
These Are the examples I used whe I installed an original inlet Filter by K&N
lotus_kn_in_situ_big.jpg and
Intake_Filter.jpg and
that's example no.2
Leo Leentvaar
PostPost by: john.p.clegg » Sat Apr 26, 2008 5:36 am
[quote="Leo Leentvaar"]These Are the examples I used whe I installed an original inlet Filter by K&N[/quote] original K&N ?
John :wink:
PostPost by: fatboyoz » Sat Apr 26, 2008 6:15 am
Vanden Perre wrote:Hello,
Thanks.
Olivier
Olivier,
I have posted some photos of my filter installation in the photos section of Yahoo Autos Lotuselan under Air Filter Mounting. http://autos.ph.groups.yahoo.com/group/lotuselan/photos
If you have an Elan Parts Manual, turn to the cut-away on page 10 and you can see how the filter is angled toward the radiator to stop debris/water from entering the inlets.
Also in the parts book on the diagram-page E10 you can see the two mounting brackets required. I found I had to twist the larger sheet metal bracket to get it to fit satisfactorily. I found, that if I tilted the top of the filter housing toward the front of the car, the ducting fitted a lot easier and with less of a bend.
Colin.
fatboyoz
Users browsing this forum: ericbushby and 25 guests
