fuel "tee"
I have a brass fuel tee that replaces the original plastic tee on my Zenith Stromberg federal car.
The 1/4" fuel line is slightly larger than the tapered fittings in the carbs. With the hose clamp tight some fuel weeping is experienced.
I replaced the 1/4" I.D. fuel injection hose with 3/16" fuel line hose and it requires a push with slight hose stretching over the carb fittings. Seems to be correct. Unfortunately the "tee" is 1/4" and the hose is streched a bit more than I am comfortable with.
I assume all federal (U.S.) Zenith Stromberg carbs have this "problem".
I need to source a 1/4" x 3/16 x 3/16 brass barb fuel tee. Any suggestions?
Bob
Bob
- rdssdi
Hi Bob
A 1/4. 3/16. 3/16 tee should be available from your local hydraulic supplier
Alternatively get a female tee and screw in the necessary hose tails.
Another option would be to fit a reducer piece just before the tee to change it to the size you want.
E.g get a 3/16 tee and a 1/4-3/16 straight reducer.
A trick I use for changing diameters of hoses is to get an inline fuel filter which usually has two hose sizes each end ( its stepped with a 3/16 barb that increases to a 1/4 barb) and use that as an inline adaptor. Its cheap and gives you extra filtering.
Clive
Clive
1972 Elan Sprint FHC
- cliveyboy
There is little distance between the carb fuel inlets. They are quite long and leave little room between for a tee. I will measure this distance today. I will try to find a 3/16 x 3/16 x 1/4 tee.
Thanks.
Any U.S. listers able to post a picture of their fuel tee on a stromberg feeral +2?
Bob
Thanks.
Bob
- rdssdi
