leaking petrol filler cap-poll
Well, just returned from Donnington and an old problem has re-surfaced,petrol all over the rear quarter ....and a light bulb just switched on over my head....is it due to my petrol cap being of the locking type?
Because there are two cut-outs in the sealing flange?
Can we have a straw poll...will those with this problem let us know if their petrol caps are locking or not.....
Mine locks and doesn't leak.
But forgot that I get major fumes in the cockpit when the tank is full
... as I was reminded, after filling up on the way to Donnington.
Stuart
Stuart
- stuartgb100
My tank was only half full,or is that half empty?,but must be caused by throwing it around a bit and fuel sloshing up the filler pipe....
Mine is original and is non-locking. I have to replace the rubber sealing ring regularly because it splits (I just cut out another piece from an old sheet of dubious quality). It then seals OK.
Mind you, I has to fiddle around with the centre spring arrangement to get the sealing ring to sit squarely and seal. You also have to get the centre bit to seal at the same time. I used rubber grommets cut to suit for that - not easy but possible.
Dave Chapman.
Dave Chapman.
- david.g.chapman
Mine originally locked (wel originally since I bought the car??) and didn't leak and I have since changed it to a BRAND NEW shiny locking type and it stil doesn't leak !!
I did find when I first got the car that it DID leak and this was because the PO had fitted the locking mechanism the wrong way round on the lock shaft and it was not allowing the seal to sit square on the neck !
Cheers and have fun
Cheers and have fun
Peter Mallinson
[email protected]
[email protected]
pmallinson - Second Gear
Mine doesn't lock and leaks all over the rear ? panel.
Hamish.
Hamish.
Hamish Coutts - Fourth Gear
locks and leaks. But I have made a very simple version of this:
http://www.lotuselan.net/publish/article_350.shtml
out of an empty vitamin tablet bottle - very Blue Peter. No leaks yet but will let you know after a track day. If it works I'll post photos.
best regards, iain
best regards, iain
- iain.hamlton
Mine locks and has never leaked in over ten years. Guess im lucky
Dave
Dave
- Dave_Newcastle
Hi There
Locks and no leak. Having that have not had the tank more than half full...... will be filling it up for a long drive next weekend so will report back if it does.
Berni
Berni
berni29 - Fourth Gear
Users browsing this forum: alex.mcguffie and 20 guests
