Fuel Pipe Route
Hi All
OK I admit it! I forgot to thread the fuel pipe through the chassis while the body was off my S4.
I imagine it's a b*gger to get it through now.
I wonder about running it inside the car?
Anyone got a bright idea or already tried it?
I routed mine with the body on. It's almost a straight line from the tank outlet through the upper right side of the back bone. There are holes provided in the factory bulkheads. I think this is where the brake line used to be before I moved it to the other side. Purchase an 5' piece of brake pipe and connect it to the tank via a compression fitting. At the front end, use rubber fuel hose to go to another short piece of brake pipe that can go into the pump. Good luck!
Frank Howard
'71 S4 SE
Minnesota
Frank Howard
'71 S4 SE
Minnesota
Frank Howard
'71 S4 SE
Minnesota
'71 S4 SE
Minnesota
- Frank Howard
