Fuel Pump
I have just removed the webers from my +2s130 and thought I would have a look at the fuel pump. In the manuel the only pump described has a domed glass top cover. Mine doesnt have this.
Does anyone have an idea what pump I have and is it an original fitting?
I had thought to overhaul it while the carbs are off.
- chrishewett
Chris,
The mechanical pump is probably a replacement one (most of them didn't have glass domes). If it fails it will leak petrol into the engine and dilute the oil. Not good for a twink!
I replied to your message but forgot to mention blocking off the mechanical mounting point. Thanks steveww!
Hamish.
Hamish.
Hamish Coutts - Third Gear
I agree with Steve. I blanked mine off with a nice aluminum cover and have an electric pump in the boot. Much quicker to start, especially when it is hot, as it often is here in Forida.
Mike Geiger
66 S3 Coupe', no more
type36lotus - Third Gear
I have no desire to buck the trend of these responses, or make any recommendation, however, I did notice an original type fuel pump on ebay earlier this evening - glass domed and brand new I think. If you are interested, do a search for 105E and you'll find it.
1965 Elan S2
- Matt7c
The original pumps (with the glass bowl) were made by AC Delco (as were the airboxes). I have never had any problems with mine and the glass bowl has beeen quite useful at times when trying to work out why the car would not start. The glass dome seals on a rubber gasket in much the same way as the top of the 'flat' type so I don't see why it should leak any more than the others. There is also a filter in the dome to stop junk from the fuel tank blocking the carbs.
Carl
Carl
pereirac - Fourth Gear
