Gas Tanks
I have a 67 elan SS s3 and have had the gas tank cleaned out. The exterior of the tank is coated with a tar coating..... Is this the original sealer or did some one goober the stuff on? If it's not original... what is?
Greg Foster
Greg Foster
- Greg Foster
Hi Eric, Good to hear from you.
I haven't had time to work on the block as I also want to set up the head and blueprint everything at the same time. Still looking for a weber head although I could pull one off another car I have.
My +2 elans both have smooth paint on the gas tanks, no tar coating....and I believe they are original.
Greg
Greg
'67 s3 SS
'72 +2 S130
'72 +2 S130
- Greg Foster
Undercoating was popular back in the 60s-70s which sounds like what yours is coated with. The idea was to prevent rust/corrosion. Is the underside of your car sprayed with the same? It's a royal mess as fuel will break it down as will most petro solvents. FWIW: My S4's tank was just painted black, no crinkle finish nor tar.
fj..
fj..
1969 S4 45/9297
grat - Second Gear
I think I will strip the tar off the tank and paint with a quality epoxy or similar. Thanks for the replys!
Greg
Greg
'67 s3 SS
'72 +2 S130
'72 +2 S130
- Greg Foster
