Lack of power when turning left?
After a lot of graft, and many conversations talking to keith I have got the carburation on the twinc going nicely..
picks up from next to no revs in 4th, good progression, good CO and hydrocarbons..
However one thing elludes me..
When I turn a sharp left the car bogs. I can't tell whether its leaning out or flooding (its hard to use a colour tune when driving, and I don't have one of those fancy wideband O analysers).
The car runs of Dells..
Anyone had this problem, and knows how to fix it?
tdafforn - Coveted Fifth Gear
At a guess it sounds like a carb float level problem, or maybe a fuel pickup problem in the tank.
You can run a colour tune while you are driving along - you just need a "helper" who won't let go of the wiper spindles, preferably one with a slimline arse and added lightness so the car's performance isn't affected too much.
Martin
72 Sprint DHC
72 Sprint DHC
M100 - Fourth Gear
When I was a lad my best friends mum couldn't make a left turn without mounting the kerb so whenever she went out she used the A to Z to plan a route so that she only turned right. Maybe this could help with your problem.
As an aside, she was a member of Mensa!
- chrishewett
Tim, Martin's suggestion of float levels makes a lot of sense. Did you check them in-situ as Keith suggests? I have seen very few that are correct even after a rebuild when measured in-situ.
-Marc '66 Elan DHC (36/6025)
http://www.lotuselan.us
- marcfuller
I mean using a clear acrylic rod as per Keith's DCOE tuning paper, to measure how far the fuel level stays below the passageway that connects the well to the auxiliary venturi.
The in-situ measurement allows float level to be set perfectly and takes into account variations in float buoyancy and fuel.
- marcfuller
"Anyone had this problem, and knows how to fix it? "
Fit a diesel?
Fit a diesel?
