fuel stabilizer
Hi Chaps, does anyone know of a fuel stabilizer available in UK and who stocks it ? Both Wynns & STP ignored the emails asking for stockists ?
As I believe the product wud be volatile and therfor not suitable to be mailed, wud need stockist in the S. Bucks, E Berks West London fringe ideally ?? Any ideas pls. Thks jc
- john-c-elan+2
Hi Jason, I mean the stuff you add to remaining fuel in petrol tank to stop it 'going off'. Lots of posts here on how fuel changes if left in tank for any length of time. Dave answered for the US - will see if its available here.
Thks john
Thks john
- john-c-elan+2
if you are looking for storage over the winter I fill the tank with gas-------- [ petrol if you wish]and add 8 oz of rubbing alcohol ---costs about a buck and absorbs the water from condensation and burns away in the first tank with no adverse effects ---draining the tank encourages rust--- a full tank wont allow oxidization as the fuel seals the inside walls of the tank---- ed
Avoid the expense, just run down the tank as far as you can, squirt some vaporising oil spray in there to cut down on corrosion and then fill up with fresh fuel when you need to use the car again.
If you really need stabiliser the only other place I think might be worth looking is in the marine industry. I've seen stabiliser and biokiller for diesel in chandlers on many occasions but petrol in marine usage is rare for safety reasons. Outboards are the only real application left but the usual recommendation is to drain the tanks.
Martin
72 Sprint DHC
72 Sprint DHC
M100 - Fourth Gear
Anyone that deals with lawnmowers should stock it. The biggest cause of lawnmowers failing to start in the spring is stale fuel in the tank all winter.
Gums and varnishes build up and precipitate in the carb and fuel lines. When I sold lawnmowers I used to stock fuel stabiliser.
- chrishewett
Try GT Autochemilube in Banbury, www.gta-oil.co.uk
Alternatively there's an American product on e-bay (yes, another e-bay addict), item number: 8042613245.
Jon
Jon
1972 Red Plus 2 S130/5
- Jonty5speed
Users browsing this forum: joe7, lotusfan, rgh0 and 11 guests
