Choke/accelerator cable
i use tape on the end and a handygrinder with a cutting disc ---ed
Solder the area to be cutoff with silver-solder first. Carefully grind through the soldered wires to shorten the cable to the desired length. For the choke cable solder 1/2" long areas where the setscrews get tightened onto the cable and the very end to prevent it from splaying all apart. Neat as a pin and it will never fray.
Soft solder works okay too. The wires can be more easily ripped free when grinding the cable in two though. Never try to cut the soldered cable with any type of cutters.
Practicing a few times makes the process much easier and a lot less stressful.
- type26owner
Solder the cable then with a sharp cheisel give it ONE hit resting on a solid metal surface ie a vice through the solder
Regards John 1969S4DHC
- triumphelan
Really sharp good quality side cutters work OK
They must be good'uns not ?2 off the market ones
Users browsing this forum: stugilmour and 19 guests
