Richness screw not working (weber 151)
Weber 151, should be fitted with the following parts. 56 64750.003 the adjusting screw with longer shank. Part 46 58000.006 cup shape washer. Part 41565.002 sealing O ring. These components provide a solution for air being drawn in around part 56. adjusting screw.
- Craven
Putting grease around the screw isn't a fix. If it didn't need grease before to run properly it shouldn't need grease now. The grease is a band aid cure of the symptoms and not a root cause fix.
You likely have an air leak somewhere if the grease improved the situation. Did you check the carb to head sealing rings?
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
Craven wrote:Weber 151, should be fitted with the following parts. 56 64750.003 the adjusting screw with longer shank. Part 46 58000.006 cup shape washer. Part 41565.002 sealing O ring. These components provide a solution for air being drawn in around part 56. adjusting screw.
Correct, all 151's should have the cup washers and O rings to stop air leaks like this.
Previous :-
Elan S3 DHC SE SS 1968,
Elan S3 DHC S/E 1966
Elan S3 FHC Pre-Airflow 1966
Previous :-
- elans3
Niklas
Are the air bleed valves closed or have they been adjusted.
+2s130 1971
+2s130 1971
Hawksfield - Fourth Gear
Niklas
As mentioned above these carbs should have the longer needle, cup and seal washer, although the carbs are only a year old, have you checked the condition of the O ring sealing washer. Sometimes the material they are made from can be of inferior quality and may not then create a good seal. If the grease you put around the screw gave an improvement this seems to indicate you you have found part of the problem, so perhaps the seal needs replacement, worth checking
Tony
Tony
- tonyabacus
