fuel hose deterioration
I put stainless braided hose in my +2 in 1994. It is the 'real' stuff, with teflon inside. Still fine
There are many brands of build it yourself ss teflon line around and all the fittings seem compatible within the teflon realm, but not in the rubber.
They make it with a black nylon overbraid and black fittings so it does not need to look so gaudy
Interestingly you cannot use it for the clutch hose, as the heat causes it to creep over the fitting, so I have a standard rubber ss hose there
- gus
Good call Gus.
For my '65 Mustang EFI conversion I'm using Teflon lined braided AN6 hose.
The vendor with the best product at the moment seems to be Fragola. They have inexpensive nice hose ends and the hose itself is graphite lined which helps with static dissipation.
The only down side is that the ends are the old "cutter" style ends rather than the FAR easier to assemble compression style ends. I haven't built the hoses yet. But it shouldn't be too bad.
-Kyle
-Kyle
'70 S4 Elan - Cosworth BDP & Spyder Chassis
'62 S2 Super Seven Cosworth
- disquek
Here are a couple of pictures showing the hoses a friend pulled off his car recently. They had been on for about 4 years and as you can see are badly cracked, but were even worse inside when cut open. As you can see they are R9 and have been used with Ethanol E5 fuel here in the UK
Tony
Tony
- tonyabacus
I have never trusted the original style braided fuel hoses and removed them and cut them up and reused the fittings with quality hose clamps and OEM quality rubber hose ( normally Gates) and never had any issues. The reproductions of the original style braided hoses you buy now I would suspect the quality of the hose even more and you cant see it deteriorate inside the braiding until its too late.
Last year looking for the lowest ethanol content fuel for aviation use, I took samples of fuel from BP 95 and 98 hoses, also Tesco 95 and 98 and tested them for ethanol content.The following day I took more samples. I don't have a log of findings anymore, but the ethanol content varied substantially. None of them showed the 5% which was marked on the pump.Twice I had readings of 1% the remainder were in the region of 3 to 6 % and one read 9%. I remember there was no great difference between 95 and 98 rating fuels regarding reliability of advertised content. I assume 5% must be an average.
I don't know how it is mixed, but if someone filled up at the time a particular pump was giving 1%, then I suppose the remainder of the fuel in storage must be higher. Makes you wonder. Incidentally my checks were verified for errors.
no need to worry, just for interest.
- Chris
Users browsing this forum: tonyabacus and 43 guests
