Airbox seal
• Page 2 of 3 • 1, 2, 3
Richard,
I have always liked the look of the Pipercross filter and it's greater air flow. I have been told to use the original air intake in front of the radiator to get cool air. Have you notice any difference with your system? Maybe, only when racing it would make the difference.
I just replaced my seal with a rubber one with a grove. Supplied by rdEnterprises and it fit!! There always has been a gap/leak on my air box. When I got the new seal and tried to fit it to the fiberglass intake cover, the pre-cut and glued seal was too long. THEN I realized that it belonged on the metal side of the intake system, not attached to the fiberglass cover.
Here is what my seal now looks like.
I like the ability to see a picture of a part on a subject. There are different terms used for parts/bits etc. I hope this what you guys are talking about.
I also just attached a larger K&N air filter and attached it in front of the radiator and I did notice a big difference with the added air flow. I still need to make up a support bracket.
Sarto
Sarto
lotus elan 1966 S3 FHC
36/5785
LHD
36/5785
LHD
mac5777 - Fourth Gear
hatman wrote:I used a Lotus airbox seal on my sash window but it got sucked into the street by passing traffic.
must be because the windows arent balanced properly, or your house is too close to the road?
- tower of strength
Hi Sarto
The Pipercross filters seem to work OK but I was worried about cool air to them, so used the old Elephant trunking to collect cold air from in front of the radiator to feed the front carbs. I added a funnel shape to the front of the trunking to ensure lots of cold air got to the carbs. This goes right to the fibregalss at the front of the bonnet at the radiator air intake. Could not do better I think - and hope!
Removing plugs after an event showed they were all the same colour.
Whatever I did with the seals I always found some grit in the airbox - even new rubber seal plus silicone sealant, so will be interested to hear how your sealing wworks after a month or so - very dusty in Greece so possibly worst place to have the problem.
Originally I just replaced the standard Lotus tin filter with a cone shaped K and K unit but somehow grit still was sucked in through the air box seals.
- paros
The last one I remember getting for either Rd or Bean was a neoprene like materiial , the profile was a cylinder with a slit . I glued this to the fiberglass 1/2 of the airbox with 3M weatherstrip glue. It was soft enough to conform to the metal 1/2 of the irbox and never gave any problems.
- cabc26b
Well i did what Chris did and ordered a rubber strip from Christoper Neils, apparently it's a bumper seal from an Eclat or something like that.
Chris, if you're reading this, can you tell me wether you fitted the seal to the airbox or the backplate?
Robbie
Robbie
I've resuscitated this thread as I have been looking for a new replacement seal for my Plus 2 airbox cover. The one in the photos is an original from a car which has been in retirement since it was nearly ten years old. It looks rather simple and possibly can be found in a motor factor's. Does anyone recognise it and know where it may be sourced?
Many thanks,
Si
Many thanks,
Si
Si_130/5 - Second Gear
"Woolies" were mentioned in the thread above.
Here's what they list. 2nd one down, maybe?
http://www.woolies-trim.co.uk/c-322-extrusion.aspx
HIH, Cheers - Richard
- ardee_selby
Here's another possibility......
http://www.sealsdirect.co.uk/shopping.asp?intDepartmentId=4#21
S4 DHC
S4 DHC
- oldelanman
Quote: Thanks Roger, that's a useful site
Yes, I second that. Thanks for the heads-up on that, Roger.
Q. What is the car in your ID picture? It seems to have the front of an S3 Esprit and an Elan roofline and rear.
It's the worlds only "Espran" (or reminder to self to be careful when ordering body sections !!! )
S3 Elan? or S3 Esprit? Make sure you're not talking at cross purposes placing a phone order!
Cheers - Richard
Cheers - Richard
- ardee_selby
Ah - just noticed I didn't get a reply from my last post (2006)!
So, does one fit the seal to the backplate or the airbox?
Robbie
Robbie
Users browsing this forum: pcarew and 25 guests
