Weber - gas coming out of 1 throat
h20hamelan wrote:I had thought you had posted elsewhere, with a photo of some older plastic line.
I don't believe that was me. The line from the pump to the Webers is steel braided
Paul Carew
Austin,Texas,USA
1967 Lotus Elan S3SE Right Hand Drive, FHC 36/7152 BOO 758F
Austin,Texas,USA
pcarew - Second Gear
ah, it was to the pump, from the chassis line.
So nylon (50 yr old) to steel to nylon (50 yr old) to pump to braided to carbs.
Love your Mother
Earth
Love your Mother
Earth
Well, I had some time today to open up the fuel pump.
A few things I've noticed. It looks like the FP has been rebuilt in the past and the internal components actually look ok.
Biggest concern is what looks like Pitting in the casting (Photo attached).
I'm wondering if this was not allowing a good seal between the glass bowl and the casting, thus the leaks.
Thoughts anyone?
Thoughts anyone?
Paul Carew
Austin,Texas,USA
Austin,Texas,USA
It also looks like the valves have been previously replaced.
Does this Spindle Seal look like it is in good enough condition to stay or should I replace as a matter of course (I'd have to find and purchase one)?
Paul Carew
Austin,Texas,USA
Austin,Texas,USA
I also noticed that the spring in the lever is very floppy and not acting as a spring at all. I'm thinking that the tiny rivet that attaches it is working loose.
Paul Carew
Austin,Texas,USA
Austin,Texas,USA
I have the Fuel pump back together.
The small spindle retaining clips were a royal pain to re-stake.
Moved on to trying to measure the fuel pressure from the pump currently on the car. Ran into an immediate problem with the connection threads. Both the current pump on the car and the AC refurbished original have 1/2 inch-18 threads. The fuel pressure gauge has 1/2-20 and won't connect!
Paul
Paul
Paul Carew
Austin,Texas,USA
Austin,Texas,USA
@steve lyle ,
Did you have any issues connecting your gauge to the fuel pump?
The thread pitch seems to be an issue for me
"I got a low pressure gauge from Amazon. The one I got was 0-5 psi, but 0-10 or 15 would do. Just don't get a 0-100. With the carbs off, I plumbed it into the output of the fuel pump"
Paul Carew
Austin,Texas,USA
Austin,Texas,USA
pcarew wrote:@steve lyle ,
The thread pitch seems to be an issue for me"I got a low pressure gauge from Amazon. The one I got was 0-5 psi, but 0-10 or 15 would do. Just don't get a 0-100. With the carbs off, I plumbed it into the output of the fuel pump"
I put a barb fitting on the gauge. Then fuel hose on that. Slipped the hose over the stub pipe that’s connected to the pump output with a compression fitting and clamped it on with a jubilee clamp.
Steve Lyle
2007 BMW 335i Coupe
2007 BMW 335i Coupe
steve lyle - Fourth Gear
gjz30075 wrote:Paul, if you need a stub fitting for the pump, I'm pretty sure I have one. Let me know.
Thank you Greg for your kind offer. As it happens, yesterday I was able to find a threaded to Barb fitting from a local car parts store.
Part "Dorman Fuel Line Adapter 785-402D" ( https://www.dormanproducts.com/p-35879-785-402d.aspx ) has the correct 1/2inch-20 thread fitting.
Thanks Steve, that's more or less what I've ended up doing too.
Paul.
Paul Carew
Austin,Texas,USA
Austin,Texas,USA
Well, I just measured the pressure from the currently attached Fuel Pump....it's a whopping 10PSI no wonder I have a flooding issue!
I'm using a new Pressure Gauge from Harbor Freight ( https://www.harborfreight.com/fuel-pump-and-vacuum-tester-62637.html ), but I can't rule out it's calibration being off. It does have a pretty high review score though.
I believe the pump that is currently on the car is a pump that may have been supplied a few years ago from RDEnt. It has the priming lever. I can't be definitive because it was a garage that obtained and fitted it, not me.
Irrespective 10PSI is off the chart. Now on to replacing with the refurbed original I have.
Paul Carew
Austin,Texas,USA
Austin,Texas,USA
Hi Paul,
So pleased you went the extra mile to prove to yourself what I have been preaching to anyone I come in contact with for some time now that the all metal mechanical fuel pumps that most of the usual suppliers are selling are just not suitable for our cars!
Delivering 10psi is totally unsuitable and will cause flooding no matter what carburettors anyone has fitted..
Note:-There are now also new imitation AC chinese or wherever glass bowl pumps on the market and being sold by Lotus suppliers that also deliver a totally unsuitable fuel pressure!
Only the original AC pump as spec'd by Lotus for the Twink will do.
Anyway....It seems you are getting there
Alan.
Alan.
'71 +2 S130/ 5speed Type9.
- alanr
Users browsing this forum: joe7 and 12 guests
