fuel odor, again
I placed several gallons of fuel into my new alloy fuel tank vented with Mocal breather vent valves.
I
Today, I had a very strong fuel odor in the trunk (boot). Apparently the Mocal valves only control fuel passing not also closed to the atmosphere as I originally thought.
I have contacted Mocal and asked for an explanation of the vent.
I have plugged the vent hoses as they exit the car.
If that is not a temporary solution to the odor problem I will unplug the vents and seal the filler cap vent. As the vent hose is 5/8" fuel line and new, I doubt the fumes are permeating through the rubber. The filler neck elbow is also new and installed correctly.
Its back too the drawing board. The fun of Lotus restoration
Bob
I
Bob
- rdssdi
In an attempt to make my boot (trunk) free from fuel odor, I plan on re-attaching the vent hoses, gauge sender and rubber filler neck elbow using Hylomar blue. I am speculating that a "dry" rubber to metal fitting may be permeable to vapor leaks.
If anyone is still having fuel odor problems, it may be worth trying. Also a good time to replace the gauge sender gasket and rubber elbow. The Vent lines on an original car would be difficult to replace but a worthwhile venture.
Bob
Bob
- rdssdi
