Wanted - Rear crankshaft lip seal carrier
PostPost by: CG901 » Mon Sep 02, 2024 4:46 am
For the later 6 bolt crank. Rear oil seal carrier.
Current: 1965 S1.5 26/4004, 1966 S3 FHC 36/5192, 1958 Fiat Abarth 750GT Zagato, 1967 Brabham BT21B, 1988 Arrows A10B-04, 1991 Brun C91-001.
Past: 1971 Elan S4/SE DHC, 1972 Europa Special, 1980 Esprit Turbo, 1988 March 881-05, 1990 Leyton House CG90105
CG901
PostPost by: rgh0 » Mon Sep 02, 2024 7:22 am
Note there are two widths of grooves for the sump gasket semicircular seal. The earlier ones had a narrow groove for a cork seal and the later ones a wider groove when Ford changed to use a rubber seal. I believe Lotus only ever used the narrow groove and cork seal on the twincam but many engines will have been modified and the later wide groove ones fitted. You need to ensure you have the right semicircular gasket that matches the it
PostPost by: dthompson002 » Wed Oct 23, 2024 10:43 pm
Narrow groove version available with lip seal.
Contact: [email protected] for pics and price please.
Southern CA USA
dthompson002
New-tral
PostPost by: Mike Ostrov » Thu Oct 24, 2024 1:15 am
I have a couple as described by Rohan. Cheers. Mike.
[email protected] or (5l0) 232-7764
Mike Ostrov
