Fail Unsafe Right Hand Headlight Pod
As the title says, I have a duff pod on the right hand side of my 1965 Elan S2. Unfortunately, that is the one that opens the micro switch so I cannot just isolate it and have one headlight...I really need a replacement. None of the usual suspects (RD Ent. Dave Bean or JAE in the USA have any, nor do they have a repair kit or suggestion.
HELP!! Any solution gratefully accepted so I can drive after the sun goes down and the Prince of Darkness is about.
- Ross Robbins
If the diaphragm is OK then the pod can fibre-glassed over and will still work, this one did.
Ross,
If the wiring around the lighting is exposed it might be trivial to put a jumper across the two microswitches so that they are wired in parallel. Then, if either one fails or a pod fails to rise, then the other will do the honours.
It'll depend on what access you have to the bullet connectors by the relays, and if they are two-way or three-way. From the S4 wiring diagram, connect BP to BR.
I've always thought that they should have been wired in parallel to start with. I paralleled mine when I was fixing the wiring many years ago.
Nick
Nick
elanner - Fourth Gear
Thank you to all of you with suggestions for my tale of woe.
As so often happens in this wonderful community I have been offered a LH pod for the shipping cost by the magnificent Gary Boudreaux which I am eager to accept IF it will work merely by plugging the extra port. It seems that it should work to me but I only know enough to be dangerous!
Can anyone who is familiar with these early cars reassure me before I ask Gary to pack and ship something that won't work?
- Ross Robbins
Hi George,
I hope yo will see this as I tried to send a PM but I was unable to send it after I composed it. it said this:
I have received the LH pod from Gary and it will require some bracket fabrication because the pods are handed to fit the angle of the inner fender so to speak. If you have an actual right hand one I would happily pay you for it and send this one back to Gary. You can call me at 3O3 829-6O4I if you want to discuss.
Ross
Ross
- Ross Robbins
Users browsing this forum: gjz30075 and 165 guests
