Angled water union
Unusual to see an angled one - where does that go?
It looks like one you'd find in a Ford crossflow engine etc - if it is, it's probably a 3/8" NPT thread and not 3/8" BSPT as per Lotus. It also appears to be aluminium which isn't great going into aluminium. Lotus used brass ones which are more likely to come out when you want them to.
promotor - Fourth Gear
promotor wrote:Unusual to see an angled one - where does that go?
It’s for the +2 instead of the heater valve on the baby Elan.
- Elan1558
When using Aluminium fittings into Aluminum it’s always good to use some of that white Loctite anaerobic thread sealer on the threads. It seals the threads and therefore stops corrosion making the fittings much easier to remove next time. It doesn’t lock - just seals.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
Elan1558 wrote:promotor wrote:Unusual to see an angled one - where does that go?
That is normally a brass 90 deg elbow on a +2.
It needs to be 90 deg to mis the servo.
John.
- elanman999
