Twincam Jackshaft wanted
JonB wrote:jono wrote:shortened one on Ebay now at £20 BIN.
...but it's in someone's basket so be quick
I don't think that will run the fuel pump. The lobe on mine is after the middle bearing jornal.
Correct.
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
2cams70 wrote:The last jackshaft I bought from QED was bent. Whilst it rotated fine in the bearings the clearance between it and the thrust plate was inconsistent around the circumference. It may have just been a one off but the OEM original parts are most often best. BDA jackshafts had the annular groove standard but they also had an oil restrictor orifice in the block gallery.
Cheers for the heads up, I'd better check mine over to make sure it's got decent runout and endfloat.
Completely agree that original is best.
promotor - Fourth Gear
