Main Bearing Caps
PostPost by: Ianashdown » Fri Nov 29, 2024 7:07 am
My engine project has aftermarket steel main bearing caps and the markings on then is quite ambiguous, there is no Front Arrow. It had been previously disassembled and the caps had been replaced inconsistently.
My question is: Should the main bearing tangs be on the same side or on opposite side of the crank? It seems there is no consistent practice manufacturer to manufacturer, or so I’ve read. There are no obvious witness marks on the block or cap, but these will have been line bored in a specific location so it important to get them back correctly.
I’d appreciate any guidance from those that know! Failing that, I do have a stock 120E engine that I could pul a main cap to observe the tang setup. I’d rather not though.
Ian
Ianashdown
PostPost by: 2cams70 » Fri Nov 29, 2024 10:16 am
The tang cutouts sit opposite either side of the centre line of the block. That's only part of the puzzle though as you'll still have to determine which cap belongs to which bearing in the block
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
PostPost by: nmauduit » Fri Nov 29, 2024 1:54 pm
Sounds like you're going to spend an afternoon with plastigauge to sort out how best to install the caps back...
S4SE 36/8198
PostPost by: Ianashdown » Fri Nov 29, 2024 3:24 pm
That you for confirming what I previously believed. It seems logical, but I saw that other manufacturers specified both on the same side. Strangely I have not found any reference in any book or manual I have, only to put the arrow forward on the standard caps. Fortunately the caps and block are numbered, so their location is clear. Both the block and the caps are stamped with Q and the number. Anyone know a shop who uses the letter Q?
Back to the garage!
Ian
Ianashdown
PostPost by: pharriso » Sat Nov 30, 2024 7:29 am
Ianashdown wrote:Anyone know a shop who uses the letter Q?
Back to the garage!
Ian
QED?
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: rgh0 » Sat Nov 30, 2024 8:04 am
All the Ford 1500 blocks I have, come with the cutouts for the bearing tangs for both block and cap on the same side of the block ( the right hand side)
PostPost by: 2cams70 » Sat Nov 30, 2024 11:56 am
Thinking about it Rohan could be correct. It was late at night when I went into the shed after having a few wines and with the engine lying on it’s side I may have mistaken the rear of the engine for the front when I was looking at it. I’m out today and can’t have another look until tomorrow. At least it might become two things Rohan and I can agree on - that is main bearing cap orientation and original Bosch inertia starter motors being better than the rubbish you get nowadays. See 512BB you are wrong - us Australians can agree on some things.
PostPost by: Phil.C60 » Sat Nov 30, 2024 12:43 pm
Rohan is, as ever, correct. Both cutouts for bearing tangs are on the same side. As for
R which cap goes where….centre and rear are obvious, the others it’s trial and measure….
Phil.C60
PostPost by: Ianashdown » Sat Nov 30, 2024 5:40 pm
I’m heading out to the garage to see if I can see witness marks to confirm this conclusion. If all else fails, I’ll pull the sump and one bearing cap of my un-molested 120E.
Photos to follow.
Ian
Ianashdown
PostPost by: 512BB » Sat Nov 30, 2024 7:00 pm
'See 512BB you are wrong - us Australians can agree on some things'
Yes, keep it up lads. Your mental ages could soon match you're shoes sizes :lol: & boom boom, then :lol:
L
L means leave off, I am enjoying myself
PostPost by: rgh0 » Sat Nov 30, 2024 10:26 pm
One potential issue is that whoever machined the steel caps might have got it wrong :(
I would check clearances and alignment very carefully
PostPost by: Ianashdown » Sat Nov 30, 2024 11:40 pm
My faith in engineers is restored. Oh, wait . . I am one. Never mind.
The caps are stamped in a correct and logical way. I was just confused because I did not expect the tangs to be on the same side.
Once the tangs are all correct the stampings on the caps are on the same side as the stamping on the block.
IMG_0847.jpeg and
Ian
Ianashdown
PostPost by: 2cams70 » Sun Dec 01, 2024 8:43 am
512BB wrote:'See 512BB you are wrong - us Australians can agree on some things'
L
Phil.C60 wrote:Rohan is, as ever, correct. Both cutouts for bearing tangs are on the same side. As for
Not amused
IMG_1102[1].JPG and
PostPost by: 512BB » Sun Dec 01, 2024 9:47 am
Neither am I.
P1010001(3).JPG and
cron
